G-Z06's 408TT (908rwhp @ 15lbs)
Former Vendor
Just got word that Garett (G-Z06) dyno'ed 908rwhp @ 15lbs of boost with the STS kit.
The Graph looks great!
300rwhp from 4-5k rpm!
He is planning on running 18 - 20lbs along with his NX 150 Wet Kit.
Pics of his finished paint job that we did.
Regards
*I am posting this for him because he was banned from the forum he wanted to keep you guys updated*
Regards
Supporting Vendor
1 Post
Nice lookin' ride. Lots of power too!
How does the torque curve feel? You can see the "sts effect" a little bit there, but who really needs 700rwtq at 2000rpm anyway
Former Vendor
Life Time NCM #2196
One sweet looking car, this baby is wicked sounding in person and was there when he busted and wanted to see him rip up the track, are you coming back to San Antonio to run again this Saturday? If so let us know
I remember when my car was that low. I looked awesome, but I got tired of hitting the bottom of my car on speed bumps, etc.. Now mine sites almost 2 inches off the tire.
Originally Posted by I-Kandy
Also He wanted to let everyone know
He went to the track last tuesday to make a pass.
Imho the only thing nicer than seeing a Y-body with alot of power........
is a Y-body owner not afraid to go to the drag strip to actually see what the car does. Also glad to hear the small "break" he had didn't deter him from going back out to the track.
Awesome car btw.
Dame
Former Vendor
Originally Posted by kumar75150
Im bringing you guys my car in about 2-3 weeks. I cant decide between Spiral Gray or Atlas Gray.
how was the fitment on that hood?
He is running a 408CI Ironblock with 60-1 Turbo's.
Kumar please stop by!
We will get you fixed up
Originally Posted by blackbelt
im assuming upgraded turbos? more info on car please?
Heads
Cam
ETc
Heads
Cam
ETc
Powell
Originally Posted by NV THIS
I was there the whole build, The motor is a 408 Iron block built by MTI. The heads are ls6 casting ported by Greg Good they flow 35X cfm at .600. The car has a Victor JR intake manifold, I think the cam is MTI's G1 but I am not 100% sure. This is the stock sts kit with upgrade 60-1 turbos, The fuel system is a racetronix with a boost-a-pump with 60 pound injectors. (and some people only think this fuel system cant handle more 600RWHP LOL) The clutch is a spec 5 and the tranny was completly built as was the rear end. The motor, fuel system, turbo kit, clutch, boost controler and everything was installed in 2 days by Chris E. at MTI In order so Garret could make Z06 Fest. Which is crazy fast to have every part sitting on the ground and a empy car and in 48 hours have it on the dyno.
Powell
Powell
Originally Posted by Earl H
60lb injectors and racetronix w/ Boost-a-pump supporting 900+rwhp. This exactly the kind of bs posts that gets people in trouble. THERE IS NO F#CKING WAY THAT 60LB injectors, unless you have 15 of them, or a racetronix with a boost-a-pump can support 900rw or 1150fwhp without some sort of fuel supplemenation. Most people who know better will likely just sit back and not say anything and know that either you have no clue or the dyno numbers are bs. Rather than call the car or the builders on this, we'll just have to say that you are misinformed.
Earl - you're going to have to eat your hat when he comes back with a 160 MPH time slip.
How did Peter pan and mikes99corvette run ?
Let us know what those dyno queens do at the track.
I think its funny how cajundude did 8XX rwhp and no one called bs and now Garret does 9XX rwhp and its impossible.
