Instant HORSEPOWER!!!!!!
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Ok for those of you that don't want to install a kit, well here it is, add this little puppy and you are on your way!!!!!!! You will have the confidence to race 1500 rwhp cars.
Clicky
Clicky
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Clicky
Clicky
Location: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
1 Post
Sounds powerfull, I'll bet that...
in the boingy boingy mode, if you mounted two of them rear facing next to the exhaust outlets, the jet effect may get you up to a tenth better in the quarter!
I'm not an electrical engineer or and acoustics specialist, but has anyone looked into integrating a thousand amp sub into the system?
Roy
Roy
Supporting Tuner
Won't work on a C5
For most Japanese car models
Originally Posted by EnglandGreen
Won't work on a C5
Supporting Tuner
I've looked into it. You can have one of these even with a C-5. All you have to do is add a Vtec emblem and you are good to go.
St. Jude Donor '06
Originally Posted by chargedc5
I believe the best place for install is under the passenger seat
Originally Posted by Z06GMAN
NOW I know what that sound reminds me of...............A GIRL FROG because we all know a girl never farts
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Won't work on a C5
St. Jude Donor '08
Can you get a passenger ejection seat like James Bond with it?
That has to be the dumbest thing I have ever seen…at least as far as Corvette mods go.
Thanks,
Clayton from Las Vegas
Thanks,
