Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection, Meth Sponsored by
A&A Superchargers
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-26-2005, 11:07 AM   #1
Hitman1
CF Member
Hitman1's Avatar
Send a message via ICQ to Hitman1 Send a message via MSN to Hitman1
Default Forced induction effect on Engine life?
This has probably been beaten to death, but please help another newbie here one more time because I've been hearing conflicting opinions
Does a supercharge affect the engine life and reliability?
What are the pros and cons of going Forced Induction vs Heads/Cam package? Money is an issue so I cant do both.
Hitman1 is offline   Reply With Quote
Old 08-26-2005, 11:35 AM   #2
H20Vette
CF Senior Member
H20Vette's Avatar
I'm a newbie to this stuff myself, but I'm pretty sure the answer is "yes", FI/nitrous does stress the engine. I think whether it is enough to break it depends on a lot of factors, which I don't understand enough to explain (but I do know that tune is important because lean = death). I've known several friends running nitrous and blowers to do engine damage.
H20Vette is offline   Reply With Quote
Old 08-26-2005, 11:39 AM   #3
corvettebob1
CF Senior Member
corvettebob1's Avatar
Anything that increases the horsepower of the engine will have a direct effect on engine life!
However a S/C will have less of an effect then H/C because it only is there when you put your foot in it.
Let the mods begin
corvettebob1 is offline   Reply With Quote
Old 08-26-2005, 12:15 PM   #4
QuickSilver2002
CF Senior Member
QuickSilver2002's Avatar
Let the mods begin
You won’t get a clear answer on this on.
H/C just swaps out existing parts of a stock motor - so it can be extremely reliable with much less to go wrong. But, to get FI levels of power from H/C you have to go with a pretty aggressive cam and bump up static compression with a smaller combustion chamber. These cams are completely different than the stock stuff and the stress on the valve train is greatly increased (even though you upgrade the springs, valves... they don't last as long as a stock configuration). This can be heard as the car idles with that sewing machine sound. This results in much more wear and tear on the top end (even in part throttle driving) and the high static compression can result in more frequent detonation (which will damage the bottom end over time). You are also going to have some reversion with an aggressive cam and this will generally make the car waste more fuel at part throttle and fail emissions. It really depends on how aggressive you go, mild H/C setups don't have these issues.
A FI setup is going to use increased dynamic compression to make power. This basically creates almost no extra stress while just cruising, but obviously puts a pretty big strain on the bottom end under boost. There are also a lot more things to go wrong with a FI setup (more parts to break or malfunction). The real beauty of FI is that you can get near stock drivability at part throttle, but have a complete monster once you get into boost.
It comes down to picking your poison. Both will reduce reliability at some level, but it depends a lot on how you are going to drive/use it.
People who beat the crap out of the car/road race... will generally get much better reliability out of a H/C setup.
Also, the things that generally go wrong with H/C packages are much easier to fix. When an FI setup goes bad you usually end up putting in a new shortblock.
Upgrading the bottom end with forged internals can eliminate a lot of the potential reliability issues with FI, but this will add about 4k to the bill.
Another important thing to consider is the tuning. NA setups are very simple to tune and it is basically difficult to screw up the WOT part of the tune. FI on the other hand, can be very tricky since the PCM was not designed to deal with boost. Low boost levels are not a big deal, but higher levels require someone who really knows what they are doing and you have to keep a close eye on it as conditions change (it won't be very adaptive unless go with some of the stuff that has just recently hit the market).
Hope that helps.
QuickSilver2002 is offline   Reply With Quote
Old 08-26-2005, 01:38 PM   #5
AVB
CF Senior Member
AVB's Avatar
Send a message via Yahoo to AVB
What's the percentage of track vs street use?
For the street:
The difference each option presents isn't enough to make stress/reliability the reason on which option you go with. NA at 450rw is nothing like FI at the same power levels and the difference becomes night and day any higher. If you want stealth w/o going big cubes or stroked then FI.
I'm sure boost stresses the bottom more but doesn't rpm when NA wear it out more?
AVB is offline   Reply With Quote
Old 08-26-2005, 01:55 PM   #6
Shinobi'sZ
CF Senior Member
Shinobi'sZ's Avatar
Shinobi'sZ is offline   Reply With Quote
Old 08-26-2005, 03:21 PM   #7
Hitman1
CF Member
Hitman1's Avatar
Quote:
For the street:
The car will be street used most of the time with occasional few street drags. You said NA at 450rwhp is nothing like FI at the same power levels; did you mean that NA would be much more reliable at these power levels or vice versa?
Old 08-26-2005, 04:06 PM   #8
RED99
CF Senior Member
RED99's Avatar
If you had 2 motors with 500 HP each. One forced induction, and the other H/C set-up, IMO the FI would live longer. A couple reasons IMO is that a FI motor puts less stress than a Hi-compression large cam motor is, with FI you don't have to rev the motor up as high to make the same power, which takes stress off the reciprocating mass. Also I think the most stress on the rod is actually when it's on it's down stroke, not the power stroke! It's realying on the cap to pull the weight of the rod and piston, and also in air. With boost, the piston and rods goes down easier because of less or no negative pressure in the cylinder to help the crank pull the piston and rod down.
Also as Quicksilver above stated, you don't need a radical cam that will wear-out your valve train faster. You would even have better life it you could lower the compression on the LS1 down to 9.5:1 - 8.5:1.
RED99 is offline   Reply With Quote
Old 08-26-2005, 04:45 PM   #9
AVB
CF Senior Member
AVB's Avatar
sorry.. I was referring to streetability and idle or the stealth factor. FI you wouldn't know it wasn't stock driveability wise. If it were a TT you wouldn't know at all except for the BOV. If you're like most on this forum, even if you don't think so right now, 450-500 is not going to be enough and will mod it for more way before long term reliability even becomes an issue..
I agree w/ the above post.. At 450rwhp, I feel FI puts less stress on the motor. Take the time to drive a stage I TT or a mag and get a feel for how these motors don't even feel like they're sweatin it..
Old 08-26-2005, 04:59 PM   #10
AVB
CF Senior Member
AVB's Avatar
BTW, the new rear mounted turbos would work well if you're wanting to stay within a budget and they can grow with your hp needs.
If your primarily for street and don't want it to shake the walls at a light then FI is the way to go.. IMO, anyways..
Reload this Page Forced induction effect on Engine life?
Tags
cons, effects, engine, forced, induction, life, pros
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
