if you want to quite down the blow off valve, i have a way!
i have a vortech bov with a&a kit. it was to loud when going part throttle. hissing and chirping......it bugged me.
first have the bov filter point away from the driver side.
second i stuffed dense steele wool in the filter.
its fixed the problem!
I got the steele wool from auto zone....comes in a variety pack.
best mod ever!
best mod ever!
best mod ever!
best mod ever!
Roger
how could i tell if it has a negetive effect on performance?
i stuffed the steele wool in the filter wich is outside the bov.
air still exhales but is quite now.
But personally I think it is the best sound ever when they go off...two 68MM turbos @ 20PSI---people turn around from all directions to see what the hell blew up...Not quite as loud when I have the controller set @ 12PSI, but still pretty loud....
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,090 Likes
Simply use two BOV's
Half the air going threw each one will quiet them down alot.
I do this alot on 427's or really high boost cars when the customer wants it stealthy.
it seems to drive fine.
1 Post
Just a thought here, get a larger the blow off, which will lower the air velocity. This should result in less audible noise. Tial makes some niece ones.
Stuffing steel wool in valve exhaust will reduce or choke your flow. The blow off is designed to protect compressor and keep it from surging.
Surge can be compared to an aircraft wing stalling. This can promote impeller blade/airfoil vibration, which accelerates metal fatigue.
Mike
Mike
Mike
Mike
1 Post
are you sure that it is bad to stuff the filter?
This is from personal experience, I was testing impeller although not centrifugal type and deliberately put it into surge state. Temperatures increased and resonance/vibration set in, followed by catastrophic failure. Tip speed was around 1000 ft/sec when blades separated. Well you can imagine the rest – but if you like destruction, then it was impressive.
ATI and Vortech, both make very good products/kits and this is why they include BOV.
Turbos have an advantage, in which they are not mechanically coupled and slamming throttle shut has similar effect but for not as long. You can actually get turbo impeller to spin backwards if it does not have BOV!
On an ATI or Vortech, you are mechanically coupled and dumping 40+ HP into blades that can be 0.06-0.08 inch thick at root. That’s not allot of aluminum.
I would say be careful of restriction you are adding.
Mike
hey doug, is there a down side to stuffing the filter with steele wool?
I never tried anything like that, it would seam to easy to get into the engine and couse a problem.
