DTE rear end brace
It can be done with most stuff in place. Jut remove the catback.
Not too hard but not much fun either. It is never fun when you can't see everything you are trying to bolt together. You have to feel a few things out.
It would be real easy if the tranny and diff were not in the car.
Supporting Vendor
1 Post
I agree. I put mine in a few weeks ago. Not the most joyous of tasks but it can be done in 4-8 hours depending on your tools and skill. The instructions say to drop the subframe but you don't need to (although it does help quite a bit).
Originally Posted by RoadRebel
You can do it with just the catback removal assuming its a stick car.
Auto's are a different story.
Phil
Phil
Originally Posted by supercoupe01
I installed mine on a MN6 in about 4 hours on a lift. I removed the cat back and lowered the sub frame. Allow about a week for your hands to heal afterwards.
I am no stranger to busted knuckles working on this car. It is a 6 spd, I will just dropp the cross member and leave the tranny in. Thanks for the info...
Supporting Vendor
1 Post
Originally Posted by Phil @ FLP
We have only installed them on Autos and found its alot easier and faster to just drop the whole rearend/transmission.
