I have a 94 Z and need a new drivers side window. Are they the same as on a regular corvette. Any suggestions on where I should get one (GM parts direct, salvage yard etc.).
Thanks in advance.
91-96 all use the same doorglass.....You can go to Car-part.com...click in your info and your state and you will find it there...It will be under"front door glass" hope this helps
According to hollander interchange they are different... I'm not sure what it is... I do know that the regulator will work 86L to 96 Probably the window does too but there is something different... The good news is that it is not ZR1 specific like the rest of the glass..
