Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-18-2004, 02:57 PM   #1
90ZR1
CF Senior Member
90ZR1's Avatar
Default new "valet switch"?
I've got a short in my "full engine power" switch.
Where can I get a new one and what is it called?
thanks
Colt
90ZR1 is offline   Reply With Quote
Old 12-18-2004, 03:04 PM   #2
Bans25
CF Senior Member
Bans25's Avatar
thanks
Colt
I had a problem with mine also... I could not find a new one anywhere.
so I took it apart and cleaned, bent the leads a little and it works fine.
Its a very simple switch.
They are discontinued from GM.
-Bill
Bans25 is offline   Reply With Quote
Old 12-19-2004, 02:43 PM   #3
90ZR1
CF Senior Member
90ZR1's Avatar
Is it difficult to get out? What do I have to remove to get to it? It looks like I'll have to take off the shifter console first?
thanks
Colt
Old 12-19-2004, 06:10 PM   #4
Jeffvette
CF Senior Member
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
You have to remove the shifter console.
Remove shift knob.
Remove (2) 7mm crews in the center console area that hold the shifter plate down.
Remove ashtray and there is a screw underneath it.
Put shifter in 4th gear and then pull up on console going back. Make sure to remove the adapter for the cig plug.
Remove the center AC vent, (2) T-15 screws.
Remove (2) 7mm screws at base of DIC panel.
Remove (1) 7mm screw at top of DIC panel (upper right hand)
Gently pull DIC panel away, it has a metal reataining tab on the left hand side.
Remove the electrical plug for the power key. It's a three prong plug and it just slides out.
As far as a key, I have one sitting in the box, waiting for mine to die. I bought mine off of ebay 2 years ago, and have never seen one since.
Jeffvette is offline   Reply With Quote
Old 12-19-2004, 07:50 PM   #5
Bigvmaxx
CF Senior Member
Bigvmaxx's Avatar
Hi All
Can a Power Key assembly / harness from a 90 model be installed in a 91 ?
Bigvmaxx is offline   Reply With Quote
Old 12-19-2004, 09:32 PM   #6
DDSLT5
CF Senior Member
DDSLT5's Avatar
Quote:
Originally Posted by Bigvmaxx
Hi All
nope. Wired totally differently.
DDSLT5 is offline   Reply With Quote
Old 12-19-2004, 11:25 PM   #7
90ZR1
CF Senior Member
90ZR1's Avatar
Quote:
Remove shift knob.
-thanks, I'll let you know how it goes. I'll do it when I install this new CD player I just bought for it. Will kill two birds with one stone!
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Reload this Page new "valet switch"?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
