Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-17-2004, 05:11 PM   #1
not4kt
CF Senior Member
not4kt's Avatar
Default Put the Plenum back on today: HELP
Well I recieved the starter yesterday and was able to reassemble everything. I put new coil packs on as well as plugs and wires.
When I was putting everthing back together, I cam across a hard plastic hose that came from the, I believe the Evaporator canister purge
solenoid (It's right in front of the coil packs). I could not find a home for this hose. I searched for about an hour and decided to just leave it off, hoping it was supposed to be that way because I could'nt recall taking it off.
well I got everthing else back in place and the car started up but I noticed a hissing sound coming from the engine area? I let the car run for several minutes and everthing seemed to be working fine, except I noticed the idle was about 1000rpm. Proir to the plenum removal it was about 650 to 700rpm.
I drove the car about 20 minutes, and she ran great, plenty of power. I got me spped up to about 92 mph for a short bit. When I got back home, she still was idling high, 1000rpm to 1050rpm.
So I'm assuming the mystery hose is my probelm. What do you guys think?
Marcus
1991 ZR1 #1887
not4kt is offline   Reply With Quote
Old 08-17-2004, 05:20 PM   #2
Jeffvette
CF Senior Member
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
It does need to be hooked up. Take it apart and get a picture of the hose. I believe it connects into a check valve that typically will fall into the V of the block. Easy to miss. But nothing should be disconnected with the vacuum system.
Jeffvette is offline   Reply With Quote
Old 08-17-2004, 05:26 PM   #3
not4kt
CF Senior Member
not4kt's Avatar
I should have known better, but I was hoping (Praying) everything was going to work. Do think this is the cause of my high idle?
Old 08-17-2004, 07:20 PM   #4
Jeffvette
CF Senior Member
Jeffvette's Avatar
Not a doubt in my mind.
Old 08-17-2004, 10:51 PM   #5
We Gone
CF Senior Member
We Gone's Avatar
Hope this helps
http://zr1.net/gifs/vacuum.jpg
We Gone is offline   Reply With Quote
Old 08-18-2004, 02:47 AM   #6
not4kt
CF Senior Member
not4kt's Avatar
It's fixed, the hose I missed went to the bottom of the plenum, towards the front. Took her out for a spin, everything works great and my idle is back to 650rpm. I just hope the new starter cured my no start problem. Thanks for the help.
Marcus
Reload this Page Put the Plenum back on today: HELP
Tags
back, plenum
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mods Complete - Engine Dead - Help! 90Indy C4 Tech/Performance 24 07-25-2005 12:13 AM
modified stealth ram plenum mdm C4 Tech/Performance 45 10-31-2003 09:09 PM
Can't get new engine to run good.......please help dtorc4 C4 Tech/Performance 13 10-25-2002 07:25 PM
Took Plenum off to smooth out and now idle surges...Please Help Triple Black 88 C4 Tech/Performance 12 06-17-2002 02:31 AM
[UPATE 4] I Get By With A LOT Of Help From My Forum Friends!!! Very Close (MANY PICS!) Marcho Polo C4 Tech/Performance 45 05-23-2002 02:25 PM
HELP!! Pulled the trigger today VetNutJim C4 Tech/Performance 13 02-08-2002 07:07 PM
The Project........ ski_dwn_it C4 Tech/Performance 145 02-03-2002 12:59 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
