Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-17-2004, 10:06 AM   #1
modrada
Junior Member
Default ZR1 Oil Change Light
Can someone provide me with the procedure to reset the Oil Change Light on a 1991 ZR1? I bought the car and the owner kept the manual.
Thanks!
modrada is offline   Reply With Quote
Old 08-17-2004, 10:14 AM   #2
Bans25
CF Senior Member
Bans25's Avatar
from the ZR1.net http://zr1.net/ZR1_techtips.html
Tip #17: Engine oil life Monitor
To reset the oil life monitor:
A. Turn the key to the "ON" position, but don't start the engine.
B. Press the "ENG MET" button on the trip monitor and release. Then, within five seconds, press and release the "ENG MET" button again.
C. Within five seconds of Step 2, press and hold the "RANGE" button on the trip monitor. The "CHANGE OIL" light will flash.
D. Hold the "RANGE" button until the "CHANGE OIL" light stops flashing and goes out. When the light goes out, the engine oil life monitor is reset. This should take about ten seconds. If it doesn't reset, turn ignition "OFF" and repeat the procedure.
Bans25 is offline   Reply With Quote
Old 08-18-2004, 12:03 PM   #3
modrada
Junior Member
Thanks for your input Bans25!!!!!
Reload this Page ZR1 Oil Change Light
Tags
c4, change, changing, corvette, light, oil, reset, teset, zr1, zri
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Big Problems?? jhoward C4 ZR-1 Discussion 19 06-18-2003 09:04 PM
NEWBIE-OIL CHANGE QUESTION! bhamvett C4 Tech/Performance 31 10-26-2002 05:56 PM
Problems with LPE 368 ZR1 Rkreigh C4 ZR-1 Discussion 25 06-24-2002 08:55 AM
'92 Tuneup Advice linkschamp C4 General Discussion 14 04-28-2002 02:45 AM
Need Help! LT5 C4 ZR-1 Discussion 9 08-28-2001 12:12 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
