Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-16-2004, 11:28 PM   #1
Last Ride
CF Senior Member
Last Ride's Avatar
Send a message via AIM to Last Ride
Default Front Brake Cooling Duct?
Okay, so one of the pieces damaged in my accident was the brake cooling duct front valance panel. I just had it put on, but it did come with the car. Do they really help a whole lot, or will my Wilwood setup cool itself properly? I might get into racing one day, but it is pretty much drag strip only at this point. 95% of the driving is on the street. What do you guys think?
__________________
Bryan Corbitt
1978 LT1 SA--- SOLD
1991 Quasar Blue ZR1 ---Also sold
DRM 368 4.09 Gears
DRM Coilovers Hurst Shift Knob
Wilwood Stoppers GM 5 Stars
Rollbar Hurst Short Throw
Last Ride is offline   Reply With Quote
Old 08-17-2004, 01:01 AM   #2
locobob
CF Senior Member
locobob's Avatar
Your brakes will be fine, the cooling ducts are for extreme use i.e. very hard track type driving.
locobob is offline   Reply With Quote
Old 08-17-2004, 09:24 AM   #3
ZR1 MK
CF Senior Member
ZR1 MK's Avatar
Ducts are track use only. Never use them on the street. Wilwoods do very well at the track without extra cooling if you drive moderately. Very hard driving, high speed tracks and track pads require extra cooling.
ZR1 MK is offline   Reply With Quote
Old 08-17-2004, 06:08 PM   #4
Last Ride
CF Senior Member
Last Ride's Avatar
I just didn't know whether or not it would be worth while to replace the ducts on the car or just use the factory valance. Thanks.
Bryan
Old 08-19-2004, 09:39 AM   #5
ZR1 MK
CF Senior Member
ZR1 MK's Avatar
One option is to use the factory type valance for now and modify it in the future if you start driving hard at the track. I use the stock type valance modified with a cut-out and a mounted scoop purchased locally. Mine is for 3 inch hose and was fairly easy to do. If you were to use 2 inch hose as most, it would be even easier. See my webpage showing some pictures of the cut-out.
Mike
Reload this Page Front Brake Cooling Duct?
Tags
brake, c6, cooling, corvette, duct
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Do all C6's have the front brake cooling ducts? Corvette Junkie C6 Corvette General Discussion 11 01-29-2005 11:56 PM
Brake Cooling Duct or ?? AU N EGL Autocrossing & Roadracing 20 01-14-2004 12:40 AM
NEW Z06 Style Mesh Screens for Front Brake Cooling Ducts In Stock!!!! L.A.P.D. C5 Tech 33 12-20-2001 05:30 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
