Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-16-2004, 11:13 PM   #1
A26B
CF Senior Member
A26B's Avatar
Send a message via AIM to A26B
Default New Oil Pump Seal Assy Needed **BAD**
Nearing completion of engine work, opened new oil pump box and no seal. After a little research, found I should have known about that....new pumps do not come with new seal.
Seals have been discontinued by GM. John Crane, Inc. made the seals under contract for GM, but so far no luck in engineering at John Crane coming up with a number, drawing or info on the seal. The GM PN for the seal was provided to them but turned up nothing.
So... I've come a beggin'.
1. Does anyone have a new seal assy that I could buy?
2. Does anyone have a viable contact at GM that could reveal the John Crane, Inc. P/N used when GM contracted the seal out to John Crane for mfg?
Supposedly the carbon seal can be removed without breaking by using a special tool. I can't chance it with my old pump & seal. At least I can put the engine together with the old pump & seal as it is (no known or visible problems) But, if it gets broken trying to remove it, I'm really screwed.
__________________
JERRYS GASKETS & LT5 PARTS
www.jerrysgaskets.com
1994 Black/Black ZR1 #234
Lingenfelter Aerobody, SGC 415, stg 2/3 cams, Ram Air, Fikse Mach V 18x12 & 18x10
SW headers, 3.91 gears, Fidanza/Spec, custom exhaust, Ron Davis Radiator, Brembos & coil overs
A26B is offline   Reply With Quote
Old 08-17-2004, 12:44 AM   #2
cvette
CF Senior Member
cvette's Avatar
Location: I've been going to this school for 7 years, I'm no dummy!
You've got mail!
cvette is offline   Reply With Quote
Old 08-17-2004, 11:11 AM   #3
A26B
CF Senior Member
A26B's Avatar
Quote:
Originally Posted by cvette
You've got mail!
Thanks for the info Charlie!
Kurt White - White Racing Products is taking care of our future by assuming the position of the Generals parts department. New oil seal shipped from stock. Good show Kurt
Reload this Page New Oil Pump Seal Assy Needed **BAD**
Tags
a26b, oil, seal
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
VB&P front mono spring kit...may have a problem. AlwaysWave C3 Tech/Performance 51 07-19-2005 04:40 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
