Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-15-2004, 02:47 PM   #1
z76232
CF Senior Member
Default Do it yourself rear gear change out
Is it a difficult job to change out the rear gears yourself on the ZR-1? Anybody out there done it with regreats or advice?
Dave
z76232 is offline   Reply With Quote
Old 08-15-2004, 03:51 PM   #2
Greybeard ZR1
CF Senior Member
Greybeard ZR1's Avatar
It can be done, but there are numerous ways to screw it up. If it isn't set up just right, it will howl. Then you have to tear it down again to fix it.
It's one of those jobs where you have to ask yourself, "do I want to learn a new skill", or "do I just want to get the job done".
If you're not going to do this job repeatedly, you may want to turn it over to an expert.
If you just want to get the job done, find a pro to do it, and make sure he does a lot of them, and will stand behind his work, No, "they all sound like that" B.S. excuses.
Greybeard ZR1 is offline   Reply With Quote
Old 08-16-2004, 11:57 AM   #3
91vettezr1
CF Senior Member
91vettezr1's Avatar
Location: Hope, New Jersey Zr1.net registry, N.J. State Director
Default rearend
I removed the rear axle housing and mailed it to marc haibeck, he changed the gears for $850 if i remember correctly. i then re-installed the unit back in the car.it wasn't too bad of a job getting the unit in and out.i wouldn't mess with installing gears if you have never done it before.4:10 's were installed and it was one of the best mods i ever did.
go to www.zr1specialist.com for more info on the mod
todd
91vettezr1 is online now   Reply With Quote
Old 08-17-2004, 08:12 AM   #4
Greybeard ZR1
CF Senior Member
todd
That's a good deal. Marc Haibeck is one of the best.
Reload this Page Do it yourself rear gear change out
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Swapping rear gear analysis Virt C6 Tech/Performance 28 09-07-2005 09:50 AM
Do you do your own work? ericdwong C5 General 18 08-12-2005 05:22 PM
2.73 to 3.15 gear replacement (HELP) birch64 C5 Tech 31 03-25-2004 10:28 PM
Gear change Ak. Mal C3 Tech/Performance 11 10-21-2003 10:57 PM
3.07 to 3.73's What else do i need? 85vettelovin C4 Tech/Performance 14 03-05-2003 02:13 PM
Transmission & Rear End Questions :) bence13_33 C3 Tech/Performance 9 02-06-2002 11:42 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
