Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-14-2004, 12:38 PM   #1
vettl83
CF Senior Member
vettl83's Avatar
Default Need Help speedo gone whacky
My 91 has 37k on the clock and the speedometer just started going nuts. When your going 30 mph it reads 75 mph and when your going 75 mph it's reading 135 mph. No matter what speed you run at it reads faster than your going. Is the processer in the ecm going south? Time for a new ecm? Could the speedo gears be trashed? Any help would be greatly appreciated. All other gauges work fine. Thanks in advance, 84 CF 91 ZR1
vettl83 is offline   Reply With Quote
Old 08-14-2004, 05:28 PM   #2
ZR1Pete
CF Senior Member
ZR1Pete's Avatar
Do you have in the Metric setting?
If not then i would say the speed sensor is going bad, it's in the trans tailhousing.
ZR1Pete is offline   Reply With Quote
Old 08-15-2004, 10:11 AM   #3
BiZ
CF Senior Member
Send a message via ICQ to BiZ
It's the car telling you it wants to go faster.
BiZ is offline   Reply With Quote
Old 08-15-2004, 10:44 PM   #4
vettl83
CF Senior Member
vettl83's Avatar
Thanks guys, got it working again. On a hunch I disconnected the negative battery cable for 15 minutes and it started working again. Hope it lasts. Again thanks, 84 CF 91 ZR1
Old 08-16-2004, 10:38 AM   #5
VaderVette
Junior Member
VaderVette's Avatar
Default Also have speedo problems
Went on a road trip this last weekend, and on the way back my speedo started acting "funny". The LCD portion of the dash, including the speedo, odometer, trip odo, mpg, etc, areas stopped displaying correctly. I'm not sure how to exactly describe it - some sections of the numbers show faded, and some sections of numbers are showing when they shouldn't.
Does anyone have experience with a similar situation? Thought about disconnecting the battery for a while and then reconnecting, but haven't tried it yet. Could it be that the LCD is just "jammed" and needs reset (by battery disconnect), do I need a new LCD, could it be ECM? I replaced the sensor in the tranny case just last year, so I don't think that's it.
Any help would be appreciated.
VaderVette is offline   Reply With Quote
Old 08-16-2004, 03:00 PM   #6
90 Corvette ZR-1
CF Senior Member
90 Corvette ZR-1's Avatar
Send a message via AIM to 90 Corvette ZR-1
Vader are you going to carlisle?
90 Corvette ZR-1 is offline   Reply With Quote
Old 08-16-2004, 03:23 PM   #7
Jeffvette
CF Senior Member
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
I have had a similar issue in the past. My speedo would dispolay some funky numbers, had it hit 255 when I was doing 40, it would jump all over the place. Also it wouldn't display certain functions and it would kick into SES mode.
My fix was to replace the ECM after it died. Fixed the problem completely. Try to find a car the same year as yours and swap the ecm. It's a simple 10 minute job for both
Jeffvette is offline   Reply With Quote
Old 08-16-2004, 08:47 PM   #8
VaderVette
Junior Member
VaderVette's Avatar
90: I don't think I'm going to Carlisle this year. I'd like to, but I have some pretty hectic deadlines to meet at work, and already have 2 getaways planned for September (including one to watch the NHRA races at Maple Grove in Reading), and also my car is not running quite right (aside from the speedo). I'm lugging in low rpms, before the secondaries kick in, so I thought that it was a clogged injector. Now with these speedo problems, I'm wondering if the ECM is indeed bad, and is perhaps causing all the problems. I don't think I want to go limping into Carlisle and get laughed at...
Then again, it might be a good chance to try to get some info.
Reload this Page Need Help speedo gone whacky
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
