Wilwood Brakes are Installed
Re: Wilwood Brakes are Installed (xlr8nflorida)
You need to bring that ZR1 to the Viper Corvette Shootout this Sunday at BMS. I'll be there to support Kurt, are you going?
Jason
'91ZR1
Jason
'91ZR1
Re: Wilwood Brakes are Installed (ZR1 MK)
Quote:Im not criticizing at all, as the results are great looking for sure. Picture one shows lettering straight (recessed) while picture three looks like lettering has a slight arch. It might be an optical ilussion.
It's not an optical illusion Mike I have the same set-up on my car.Picture one
does have the straight lettering and it's the inside of the caliper that your looking at while the outside of the calpier has curved lettering.
:chevy :chevy
:chevy :chevy
Re: Wilwood Brakes are Installed (jaymitchell01)
[QUOTE]You need to bring that ZR1 to the Viper Corvette Shootout this Sunday at BMS. I'll be there to support Kurt, are you going?
I may go but I probably won't bring the Z. I'll bring the 93.
:cheers:
:cheers:
Re: Wilwood Brakes are Installed (BERTZR1)
[QUOTE]Quote:Im not criticizing at all, as the results are great looking for sure. Picture one shows lettering straight (recessed) while picture three looks like lettering has a slight arch. It might be an optical ilussion.
Yeah you are right now that I think of it, I must have taken the inside of the caliper by mistake. :eek:
Cruising
LOOKS GREAT ARE THEY 4 PISTON CALIPERS , DID YOU DO ANY PRE TESTS WITH CONSTANT HIGH SPEED STOPS TO TEST THE DIFFERENCE.
I AM MAKING MY OWN ROTORS AND CALIPERS 32MM VENTED ROTORS WITH
NC MACHINED BILLET ALUMINIUM CALIPERS FITTED WITH BENDIX ULTIMATE DB 1355 PADS, I AM GOING TO FIT A 10 MM SPACER PAD AT THE STUB AXELS TO GIVE ENOUGH OFFSET CLEARANCE.
GREAT LOOKING ZR1, WHAT SORT OF COST DID THEY SET YOU BACK.
REGARDS BRIAN
REGARDS BRIAN
Re: Wilwood Brakes are Installed (bkidston)
REGARDS BRIAN
REGARDS BRIAN
They stop on a dime and are quiet.
The front Kit costs is $2,200, then I had to buy the front hubs which was another $400.00 (GM) and the rear calipers and rotors were probably $500 plus new front racing pads which was $100+ so It's about a $3,000 package.
I bought the DRM for $1650 Used though so I saved alittle $$$.
Good luck on your brake upgrade
