Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-19-2004, 08:23 PM   #1
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
Default Dual fuel pump questions
Do both pumps run all the time or does one run all the time and the other only runs when called upon? Also, is anyone running two aftermarket pumps, like the Walbro's?
ANTI VENOM is offline   Reply With Quote
Old 01-19-2004, 08:26 PM   #2
Jeffvette
CF Senior Member
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
Default Re: Dual fuel pump questions (ANTI VENOM)
Both pumps run at start up when the motor is cold. When it reaches 160/170 degrees it shuts off pump #2.
With the power key at full power the secondary pump is primed and ready to go. All it needs is the computer signal to start pumping fuel when demanded.
Jeffvette is offline   Reply With Quote
Old 01-20-2004, 12:51 AM   #3
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
Default Re: Dual fuel pump questions (Jeffvette)
It seems a little weird that the pump could start up and start pumping fast enough to meet the demands of the engine. It obviously works though. I ask, because I thought of using a second pump to feed a turbo fed engine on boost only. This way I get plenty of fuel and don't heat the fuel excessively. I may be able to find a ZR-1 set-up for mounting the pumps.
Old 01-20-2004, 11:48 AM   #4
Rkreigh
CF Senior Member
the staged fuel pumps is a great way to allow the car to reach full power, but only give it the volume needed for cruzin, UNLESS one of them goes bad at the most inopportune time.
I wonder this, if the secondary pump quits with the car "code" and shut off the secondaries???
if the primary quits the car will stop, which is a hassle, but better than leaning out.
:confused:
Rkreigh is offline   Reply With Quote
Old 01-20-2004, 11:53 AM   #5
ShawnZR-1
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11
ShawnZR-1's Avatar
Send a message via MSN to ShawnZR-1
If I remember reading correctly, if the secondary pump does not turn on when the car is started, it will throw a code and not let the secondaries turn on. Also, while the power key is on, the pump is monitored and the ECM will shut the fun down if it sees a problem with it.
I need to look again and see if it actually monitors pressure. Shoot, there's like 10 pages of troubleshooting the secondaries in the manual! :crazy:
ShawnZR-1 is offline   Reply With Quote
Old 01-20-2004, 03:14 PM   #6
DDSLT5
CF Senior Member
DDSLT5's Avatar
Default Re: Dual fuel pump questions (ShawnZR-1)
If the oxygen sensor goes lean for 5 consecutive seconds at WOT, then SES is set, and secondaries are killed. :seeya
DDSLT5 is online now   Reply With Quote
Old 01-20-2004, 03:24 PM   #7
90 Corvette ZR-1
CF Senior Member
90 Corvette ZR-1's Avatar
Send a message via AIM to 90 Corvette ZR-1
Default Re: Dual fuel pump questions (DDSLT5)
We sure found out that didn't we Dwight?
90 Corvette ZR-1 is offline   Reply With Quote
Old 01-20-2004, 04:02 PM   #8
A26B
CF Senior Member
A26B's Avatar
Send a message via AIM to A26B
Default Re: Dual fuel pump questions (90 Corvette ZR-1)
Well Kevin.... you should have known! The guy ONLY drives with the secondaries open!! :rofl:
A26B is offline   Reply With Quote
Old 01-20-2004, 04:07 PM   #9
90 Corvette ZR-1
CF Senior Member
Default Re: Dual fuel pump questions (A26B)
Dwight took me for a ride in the Jeal 368 back before it was tuned. We went from spitting fire at some Nissan who thought he had something for us, to running on the primaries only in the space of about 20 mins.
Old 01-20-2004, 05:25 PM   #10
DDSLT5
CF Senior Member
DDSLT5's Avatar
My brother got me a T-shirt that has a ZR-1 on the front lighting up the tires with the saying: "Smoke 'em if ya got 'em!" :smash: :) :seeya
Old 01-20-2004, 07:23 PM   #11
Patand
Junior Member
What code will be set if this happen?
I am curious because I had a code 54 set this summer when my car stumbled big time at wot, but I didnīt see the ses light com on. I think secondarys shut off but all seemed fine after a couple of minutes....
I have changed both fuel pump relays, valet key connection checked.
Think I will change pumps too. This happened only 2 times this summer but one time too much during a race....
:confused:
Patand is offline   Reply With Quote
Reload this Page Dual fuel pump questions
Tags
2001, corvette, duel, fuel, pump
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Carter Fuel Pump Question . . . Paging lars dath C3 Tech/Performance 9 08-12-2005 11:23 AM
Intercooler and fuel system questions JordonMusser C4 Forced Induction/Nitrous 21 02-26-2004 10:31 AM
About to order an ATI Procharger P600B HO - Questions... Blueyednd C4 Forced Induction/Nitrous 37 12-27-2003 12:22 PM
Dual 255lph Fuel Pump ????'s Earl H C5 Forced Induction/Nitrous 19 01-15-2003 02:48 PM
A few Supercharger Questions... Black96Corvette C4 Forced Induction/Nitrous 9 12-10-2002 12:05 PM
502/454 questions Lasse C3 Tech/Performance 16 11-16-2002 12:05 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
