Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-18-2004, 07:38 PM   #1
ryanday
Junior Member
Send a message via AIM to ryanday
Default VATS...what a pain in the...
Not quite a KOTH question, but you guys are the best around... My '90 Z VATS keeps going off in cold weather. I am 95% sure it has to do with the door(s) and the insulation around them. I have a similar issue when I drive with my windows down. The good ole' dome light seems to flicker a bit, until I SLAM my door with the windoe down, or roll my window up. Any suggestions? Thanks for the help.
ryanday is offline   Reply With Quote
Old 01-18-2004, 08:24 PM   #2
Aaron71771
CF Senior Member
Aaron71771's Avatar
Default Re: VATS...what a pain in the... (ryanday)
Could be door ajar sensors or key lock sensors.
Aaron71771 is offline   Reply With Quote
Old 01-19-2004, 03:38 PM   #3
bad-zr1
CF Senior Member
bad-zr1's Avatar
If you know it is the drivers door that is the problem, look at the light switch on the door and in the center is a little button. Take a knife and slowly work/pull it out some. It has serrated edges on it and will pull out quite a bit. This gets pushed in over time and acts like the door is not completely closed. Check the other door as well.
:steering:
Jim
bad-zr1 is offline   Reply With Quote
Reload this Page VATS...what a pain in the...
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
I think I fried my ECM test C4 Tech/Performance 47 08-17-2005 03:39 PM
And so the pain begins................ BubbaJJ C4 General Discussion 16 11-18-2003 08:46 PM
Does an 85 have any theft deterent? If not, what's up. dmorris C4 Tech/Performance 10 11-14-2002 06:31 PM
HELP!-Any ideas why my VATS would be cutting out my fuel during WOT launches? Mopar Jimmy C5 Tech 18 10-30-2002 01:22 AM
96 Vette wont start...full power...does not turn over....please help! MaddMaxx C4 Tech/Performance 34 08-06-2002 11:28 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
