shift light
shift light
haw and witch is the best shift lite i can install on my 95 zr1 and keep it looking descreet
like for exampole in the center air vent
and what do i need to install it
thanx
:cheers:
thanx
:cheers:
Re: shift light (sultan)
Do you have an aftermarket chip? I believe the ones from Doug Rippie (maybe others too) disable the shift light. If so I think it can be programmed back in. It just seems like a pain to install something that is already there.
Good Luck,
Mike.
Good Luck,
Mike.
Re: shift light (1990 QUASAR BLUE)
dear mike thanx for the reply
i was wondaring if i installd
MSD part no 8224coil cacks
and MSD digital 6215 DIS2
i well be abol to install auto metre 5330 shift light
or MSD 7552 shift light
and have it in my meddel A/C vent
thanx
:cheers:
[Modified by sultan, 5:24 AM 1/15/2004]
thanx
:cheers:
I'm not sure there is a "best", but I installed a Harlan Shift light in the upper air vent as youmention. It uses the stock tach output, therefore there is not a need for an MSD unit etc as you mention.
Mike
Mike
Good Luck,
Mike.
Good Luck,
Mike.
Re: shift light (ZR1 MK)
Mike
Mike
thanx
i like the set up you have don and the sheft lite seam to be purfect for me
let me ask you one more thing
regarding the conection
were ded you get the RPM feed line fron and?
what ded you use as ground and ?
were did put the modual ?
any phtos well help a lot
I ask to much of you guyes
thanx again
:cheers:
Re: shift light (ZR1Pete)
Raptor owns! :yesnod: I think it's definitely one of the smallest and most well designed lites on the market. High quality & good looks to boot!
Good Luck,
Mike.
Good Luck,
Mike.
Re: shift light (Scoob)
The factory shift light is for fuel economy ( :lolg: ).
GuTu34 (02-23-2022)
sultan
I actually got the idea to install the shift light in the air vent from a guy on the Grand Sport forum. He had installation pictures and tips on the whole process. I will try to see if the site info is still available. If not, I can take a picture of my after installed unit and some tips. There is a white wire that comes from the ignition system under the plenum that is the tach feed wire. Ground wire was taken from ground source under the dash.
Mike
Mike
Re: shift light (DDSLT5)
Reread you owner's manual. It is not for economy. The factory shift light is programmed to illuminate for shifts maxmizing performance, NOT fuel economy. This is not a Cavalier.
The factory shift light is for fuel economy ( :lolg: ). The shift light being referred to here is for racing.
:cheers:
Mike.
The 95's shift light does not illuminate from the factory. The only light that does for shifting is the d@mn 1-4 skip light.
Re: shift light (Demps)
