Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-27-2003, 01:53 PM   #1
THISLDO
CF Senior Member
Default Electrical problem
The last time I fired up my 91 ZR-1 I ahd to charge the battery first. I did not give it much thought as I believed I had left the dome light on. Tried to fire the car this morning and the same problem but with a another wrinkle. When I attached the charger I noticed a clicking noise near the glove compartment. The clicking noise would stop when I energized the ignition. I also get a buzzing noise from the area near the drivers side of the radiator with the fans momentarily running. I have disconected the battery in hopes that the computer resetting and solving the problem. No luck though. Any ideas?
Joe Shown
1991 ZR-1 # 1009
1990 Jeal 415 ZR-1
THISLDO is offline   Reply With Quote
Old 07-28-2003, 05:40 PM   #2
Boofers
CF Senior Member
Boofers's Avatar
Location: Winner of the 2006 cotter pin bending championship in Hamilton Ontario
Default Re: Electrical problem (THISLDO)
Get some schematics and a mutlimeter...
Boofers is offline   Reply With Quote
Old 07-28-2003, 05:43 PM   #3
bhamvett
CF Senior Member
bhamvett's Avatar
Default Re: Electrical problem (Boofers)
I say the clicking noise is the VATS!
bhamvett is offline   Reply With Quote
Old 07-28-2003, 06:24 PM   #4
THISLDO
CF Senior Member
Default Re: Electrical problem (bhamvett)
The followiing was sent to me by Marc Haibeck. Marc is right and a new battery resolved the problem. Thanks for the response.
Joe Shown
Hi Joe,
I believe that you are charging a totally discharged battery. As the
system voltage slowly goes back up there are some devices in the car
that try to startup or initialize. Because the system voltage is too low
for them to fully operate, they will partially operate during the slow
voltage rise. You are hearing a relay that is trying to close but there
is not enough power to complete the operation. This is most noticable on
a ZR-1 when the door is open during the charging.
When charging a fully discharged battery, I recommend disconnecting the
battery and then reconnecting it after it is fully charged.
A charged battery protects the electrical system because it has a very
low internal resistance. This is similar to the way a surge protector
protects electrical circuits. When the battery is discharged, its
internal resistance goes up and the electrical system lacks protection
from voltage spikes. A car is especially vulnerable when a battery
charger is used to charge a totally flat battery. With a charged
battery, if the battery charger is connected backwards the battery will
resist the charger and probably win the battle. If the battery is
totally flat and the battery charger is connected backwards, the system
voltage could go negative. Negative system voltage can damage electrical
parts. Again it's a good practice to remove a battery cable before
charging a fully discharged battery. I think that an even better
practice is to prevent stored batteries from discharging in the first
place by using a Battery Tender or another charger that does "float
charging".
Best of luck.
Marc
Reload this Page Electrical problem
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
UPDATE - Electrical Problem Help 80TexasC3 C3 Tech/Performance 13 07-08-2005 05:13 AM
Intermittent Electrical Problem - HELP!!! Stephen81C3 C3 Tech/Performance 13 07-05-2005 04:00 PM
electrical problem, "Service Engine Soon" light Karsten90 C4 Tech/Performance 11 06-11-2002 09:00 AM
HELP! me diagnose a crazy electrical problem! robzr C3 Tech/Performance 16 08-17-2001 08:23 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
