Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-27-2003, 02:27 AM   #1
Jeffvette
CF Senior Member
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
Default Now the problems......
Got codes
31 Cam sensor not found or to high... fixed
33 Map Sensor voltag4e to high.... WTF :confused:
45 Right Bank 02 sensor rich
65 Left bank O2 sensor rich
ALso runs a bit rough, hunts for idle, possible coil pack failure possibility. Any tips on testing them?
She sounds mean :thumbs:
Jeffvette is offline   Reply With Quote
Old 07-27-2003, 08:43 AM   #2
The Lurker
CF Senior Member
Default Re: Now the problems...... (Jeffvette)
Quote:
Got codes
My god you're up early!
The O2's are rich because it isn't tuned. As I said last night, every engine is different. You can build two side by side and they will be different.
The idle is because of the cams. You can get it somewhat close in the PROM tuning but the ECM just doesn't have the programming to ever get it the way you would want it. You have a lot of overlap there and you will probably have to live with it. You can get a wideband O2 and do some tuning without being on the dyno so it doesn't cost you money.
I don't know about the MAP. Look in the manual and follow the trouble tree. I will take a look today at the shop and see what it says.
Hey, have fun and be sure to break it in right! Two hours on the stands before you put it on the ground in 15-20 minute runs. Let it cool and hour between runs. Check the oil and water each time. Vary the RPMs ad watch the temps and pressures. Used dino oil for at least the first 2K miles. C hange oil after you do the stand run in and every 500 miles after that. These are the MOST critical changes you can make! Lot's of crud running around that engine. Also change out the coolant. Keep it as clean as the oil.
The Lurker is offline   Reply With Quote
Old 07-27-2003, 08:35 PM   #3
Jeffvette
CF Senior Member
Jeffvette's Avatar
Default Re: Now the problems...... (The Lurker)
Mr. Lurker, I'll give you a call a little later this evening.
Reload this Page Now the problems......
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Windshield Replace - Now HUD Problems HOTSOSS C5 General 22 07-30-2005 06:32 PM
Now the wait is going to get worse... TedG C6 Corvette General Discussion 22 05-08-2004 02:01 AM
4-post Lift Headache - Now The Runaround 69L71 C3 Tech/Performance 32 04-25-2002 01:20 AM
4-Post Lift Collapse - Part 2 - 'Now the Fun Starts' 69L71 C3 Tech/Performance 68 04-06-2002 03:36 AM
Vette is SOLD, it's official! Now the search is on....heheheh VetteBabe1 C4 General Discussion 28 03-01-2002 08:14 PM
here come the problems..... Marcho Polo C4 Tech/Performance 11 12-05-2001 04:09 PM
NOW THE FRIGGIN DOOR WON'T OPEN!!!!!!!! 69er C3 Tech/Performance 17 09-09-2001 03:10 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
