Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-26-2003, 09:40 PM   #1
Aaron71771
CF Senior Member
Aaron71771's Avatar
Default Plenum pull and stumble finally fixed
Well, last year my car developed a stumble/miss. I repaced the plugs as it was easy to do and it did help the car run better, but I was still missing from time to time and could fell a slight miss in the upper RPM range. The stumble was very noticeable under a light load and would take a good 500 RPMs to go away. I usually most pronounced at low RPMs.
I did all the regular stuff, fuel pressure check, plug wire check, fuel filter replacement, vacuum line checks, secondary vacuum check, MAP.
The service manual recommend starting that car and while it was at Idle pull the spark plug wires one at a time. They all had a RPM drop (had EASE running) except #2, I also noticed that the spark was very weak on #2. On the other wires I could hear and see the spark inside the wire.
That was last year, fast forward to today
My car just rolled over 30,000 miles so it was due for spark plug wires. I pulled the plenum and replaced the wires and a faulty fuel canister purge solenoid. I put in Taylor 8mm red wires and four new AC Delco coils. I tested that resistance on the coils and three were the same and the coil for the #2 cylinder test quite a bit higher. I also tested the resistance on the fuel injectors which all tested either 8.3 ohms or 8.4 ohms. Put everything back together and went for a test drive.
Things are much smoother (and I thought it was smooth before). The miss it gone and so is the stumble. The car has zero stumbles under load. Looks like the problem has been fixed. Woohoo!!! :D
Pulling the plenum was no big deal, pretty easy to do and did not take very long. Getting it back on too a little longer but I would not hesitate to do it again if needed. Why do people get scared of working on these cars? I though I would be but with a service manual and this forum things can be pretty much tacked by any basic home mechanic that can turn a wrench.
Aaron71771 is offline   Reply With Quote
Old 07-26-2003, 09:49 PM   #2
BiZ
CF Senior Member
Send a message via ICQ to BiZ
Default Re: Plenum pull and stumble finally fixed (Aaron71771)
I know exactly what you mean. It looks intimidating until you actually do it. Then you're like, "Hey that was pretty easy". And as you said having a manual and the forum really helps out. It gets easier the next time you do it. And the next and so on. At SGC last year Aaron and George pulled the plenum off of George's car. That was the first time I saw it done. They had that thing off of there quick and clean.
It's nice when you go in ther on a mission and get the job done. Glad to hear you got the car running smooth.
BiZ is offline   Reply With Quote
Old 07-26-2003, 10:43 PM   #3
MrCrowley
CF Senior Member
MrCrowley's Avatar
Send a message via AIM to MrCrowley
Default Re: Plenum pull and stumble finally fixed (BiZ)
Glad to hear that your problem is all fixed now! I actually find disassembling a complete LT5 is much easier than an L98.
[Modified by MrCrowley, 8:44 PM 7/26/2003]
MrCrowley is offline   Reply With Quote
Old 07-27-2003, 05:14 PM   #4
phrogs
CF Senior Member
phrogs's Avatar
Default Re: Plenum pull and stumble finally fixed (MrCrowley)
It always looks intimidating until you start to tear into it.
I enjoyed tearing mine down the only thing that I even had a slight worry about was taking off the cam covers....
even then it wasn't the removal but the installation that had me a bit worried that damn sealant :D
[Modified by phrogs, 3:14 PM 7/27/2003]
phrogs is offline   Reply With Quote
Old 07-27-2003, 10:48 PM   #5
Chris@VetteFinders
CF Senior Member
Chris@VetteFinders's Avatar
Default Re: Plenum pull and stumble finally fixed (phrogs)
Looks like a lot of us are fixing our "hesitation" problems lately. Glad to hear that. I know mine was driving me nuts.
I Don't have any concerns about working on the "complex" (like so many people seem to think) LT5. Hell, I am sort of glad I had the hesitation problem. Now I feel like I could do anything on my car.
Chris@VetteFinders is offline   Reply With Quote
Old 09-05-2003, 05:23 AM   #6
95ZR1#418
CF Senior Member
95ZR1#418's Avatar
:chevy :yesnod: :chevy
95ZR1#418 is offline   Reply With Quote
Old 09-05-2003, 08:35 AM   #7
jamies z06
CF Senior Member
jamies z06's Avatar
have you had the injectors tested, just went thru mine and found that three were bad,replaced them had the rest flow tested, put back together,WOW what a difference, I but the car two months ago,it must of been running bad eversince i decide to look into it a bit closer i found #2 cylinder not getting fuel because the injector only ohmed out at 1.96 ohms, this car really flys now,i bought reman injectors for 45$ each for primary anyway this was my fix to get the BEAST running again
jamies z06 is offline   Reply With Quote
Reload this Page Plenum pull and stumble finally fixed
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
