Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-25-2003, 10:47 PM   #1
VetBoyZR1
CF Senior Member
VetBoyZR1's Avatar
Send a message via AIM to VetBoyZR1
Default Coplon Air Duct
The OEM air duct is as squishy as a wet twinky. At high speeds the duct collapses, restricting air flow into the throttle body. In this first pic I am squeezing the stock duct, which reveals the duct had actually been pulled off the air cleaner housing when it collapsed.
I removed the OEM duct and held it up to see how it looked from the inside. Not only is the inside diameter greatly reduced when it collapses, I can't help but feel this accordian inner surface does not flow air very smoothly. Note, I am squeezing the duct, it is not out of shape from collapsing. It is only collapsed when you are driving fast, so you may not even know this is happening to you:
Here's the inside of the Mark Coplon air duct. Notice the shiny stainless steel lining inside this baby!
Installed, it looks just like stock since it is a stock air duct with a lining. But you can't squeeze this one, it doesn't collapse from air pressure, and the flow must be much smoother:
Now to test this out tomorrow!
[Modified by VetBoyZR1, 9:41 AM 7/26/2003]
VetBoyZR1 is online now   Reply With Quote
Old 07-25-2003, 10:55 PM   #2
DDSLT5
CF Senior Member
DDSLT5's Avatar
Default Re: Coplon Air Duct (VetBoyZR1)
Mine was actually squished together at rest, and almost closed at WOT. Mine is a 90, so it is more pronounced - but the Coplon duct certainly deals with this problem nicely. Also expands the duct by 15%! Just watch the undersurface of your hood - you may need some felt on the hood to prevent abrasion - my brother's Jeals has wear marks in this spot. :seeya
DDSLT5 is online now   Reply With Quote
Old 07-25-2003, 11:28 PM   #3
2DA-MAX
Junior Member
2DA-MAX's Avatar
I have the same problem with mine. Every time I take my Beast out for some exercise, the air duct pop off from the left front. The stock air duct obviously collapses under WOT. Where can I get the stronger Coplon replacement?
2DA-MAX is offline   Reply With Quote
Old 07-26-2003, 12:22 AM   #4
Bans25
CF Senior Member
Bans25's Avatar
Default Re: Coplon Air Duct (2DA-MAX)
I also had the same problem, when I went to the track it fell off 1/2 way down! and I lost the clamp!!
I bought a Mark C. air duct and problems are gone! :D
Bans25 is offline   Reply With Quote
Old 07-26-2003, 12:38 AM   #5
VetBoyZR1
CF Senior Member
VetBoyZR1's Avatar
Send $65 total "USA Shipping only" to...
Mark Coplon, 410 N. Woodcroft Lane Schaumburg, IL 60173
Old 07-26-2003, 12:55 AM   #6
Bans25
CF Senior Member
Bans25's Avatar
I would email mark first (I will look for his email address) since he sometimes runs out...
Old 07-26-2003, 03:50 AM   #7
phrogs
CF Senior Member
phrogs's Avatar
mine original is done It also pops off on the front and it pisses me off!
I just cant ever find time when Mark has any left.
I think I am going to make my own..
johnny
phrogs is offline   Reply With Quote
Old 07-26-2003, 11:20 AM   #8
Mikez40
CF Senior Member
Mikez40's Avatar
Send a message via AIM to Mikez40
Default Re: Coplon Air Duct (Bans25)
Here is his email: "mjcoplon@tycoelectronics.com"
Mikez40 is offline   Reply With Quote
Old 07-26-2003, 01:02 PM   #9
Scoob
CF Senior Member
Scoob's Avatar
Default Re: (Coplon Air Duct VetBoyZR1)
Quote:
Coplon Air Duct
Have one. Love it. :thumbs:
Scoob is offline   Reply With Quote
Old 07-26-2003, 01:34 PM   #10
FastZR1
CF Senior Member
FastZR1's Avatar
Default Re: Coplon Air Duct (phrogs)
I have the Colon duct on my car.
But at I have seen a few guys on the ZR1.net, metal coffee cans that were worked into the duct. I have also seen guys use coat hanger wire too.
FastZR1 is offline   Reply With Quote
Old 07-26-2003, 01:38 PM   #11
90 Corvette ZR-1
CF Senior Member
90 Corvette ZR-1's Avatar
Send a message via AIM to 90 Corvette ZR-1
I want one badly. Will anyone be selling one at carlisle?
90 Corvette ZR-1 is offline   Reply With Quote
Old 07-26-2003, 03:57 PM   #12
ZR1 Jim
CF Senior Member
Default Re: Coplon Air Duct (90 Corvette ZR-1)
I had the exact same thing happen to me. The stock duct came off the air filter housing and was collapsing big time. My car felt like it was making all of 30 hp. Then I would pull over and it idled fine. I was really confused :confused: and very happy when I found out it was an easy and cheap fix. Marc had them in stock 2 months ago, that's when I got mine.
No problems at all now :reddevil
ZR1 Jim is offline   Reply With Quote
Old 07-27-2003, 03:12 PM   #13
VetBoyZR1
CF Senior Member
VetBoyZR1's Avatar
Default Re: Coplon Air Duct (ZR1 Jim)
SUCCESS! I was at the track yesterday and can now be confident that my air duct won't come off at WOT! Problem solved, now on to the next thing....
Old 07-27-2003, 05:44 PM   #14
fort94z
CF Senior Member
Hey Carl, any other ZR-1 at Englishtown yesterday, if so , how did they run?
What's next, P&P ? :)
fort94z is offline   Reply With Quote
Old 07-27-2003, 05:56 PM   #15
90 Corvette ZR-1
CF Senior Member
Carl, what did ya run at the track?
Old 07-27-2003, 10:27 PM   #16
VetBoyZR1
CF Senior Member
VetBoyZR1's Avatar
I was the only ZR-1 at the track. Last time the only reason there were 2 ZR-1s was because Garth Koniver came along with me! It was way too hot and humid yesterday to make a fair comparison based on speed. I was happy just to see the duct stay put. We were all off by 2 to 4 tenths, and my trap speed was down at least 3-6 MPH. I could not even break 110 yesterday. We had the East Coast Show and Go all morning, then the Corvette Challenge from 3 until 9PM. It was a long HOT day and some of our drivers were sicker than the cars from the heat. As for my car, I am considering doing a little something to pep it up a little. I'm undecided as to a P&P vs a 368. I just don't believe a P&P job is of as much value on a 405 car as it is on a 375. Isn't it funny how we can get used to a car that runs so nice and always want more? I'll be focused on some Verizon issues for a while (think it's called a STRIKE), but we'll see in a few months! So many guys getting 415's done makes me want to just go ahead and take the big leap. I've got a pile of parts sitting here next to me, so somethings going to happen soon!
Old 07-27-2003, 10:34 PM   #17
VetBoyZR1
CF Senior Member
VetBoyZR1's Avatar
PS I just heard from Mark. He is very pleased to see the feedback from his previous customers. He did not express any concern about meeting the demand for new orders, so if you were interested in getting one - go for it!
Old 07-28-2003, 12:19 AM   #18
90 Corvette ZR-1
CF Senior Member
Your posts still didn't answer my question Carl. :D
Reload this Page Coplon Air Duct
Tags
1994, air, buy, coplon, corvette, duct, il, illinois, intermediate, mark, schaumburg, shaumburg
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Coplin Air Duct... 9T ZR-1 C4 ZR-1 Discussion 17 06-17-2005 04:08 PM
Air duct collapse ? Mylzi C4 ZR-1 Discussion 20 11-07-2003 04:20 PM
Differences between stock duct and Coplon duct.s DDSLT5 C4 ZR-1 Discussion 29 12-21-2002 10:17 PM
I need a Mark Coplan air duct or similar!! Bans25 C4 ZR-1 Discussion 12 11-03-2002 08:20 PM
Replacement for air bridge? BCZR1 C4 ZR-1 Discussion 12 04-26-2002 05:49 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
