Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-24-2003, 01:22 PM   #1
yoslambo1@cs.com
CF Senior Member
yoslambo1@cs.com's Avatar
Send a message via AIM to yoslambo1@cs.com
Default Matching #'s?
I was told that in the past gm would remove a zr-1 engine when it had a problem & just put another one in.....how will that effect the value in the future? I know a non matching # car is worth less! How many zr-1's have non matching #'s? :confused: Im not trying to start trouble (ive been known to mess with you zr-1 guys about your boat engines :jester ) I just wonder what the zr-1 community thinks? :blueangel:
yoslambo1@cs.com is offline   Reply With Quote
Old 07-24-2003, 01:29 PM   #2
DDSLT5
CF Senior Member
DDSLT5's Avatar
Default Re: Matching #'s? (yoslambo1@cs.com)
If done (and it didn't happen to many), it would have been a factory replacement. Everyone that had this done had the option to have their original engine re-installed, but not many likely bothered. I doubt it will make any difference - just as long as it is an LT5, and not an LT1, like that one that was for sale on Ebay not too long ago!! :seeya
DDSLT5 is offline   Reply With Quote
Old 07-24-2003, 03:32 PM   #3
90 KOTH
Junior Member
90 KOTH's Avatar
Hopefully there's an expert out there that can confirm this but I don't recall that the chassis serial number is anywhere on the LT-5 original or not. There's a engine serial number on the pan rail that you can determine the date MM built it and the sequence number for that days production, but I don't think the VIN was stamped on the block.
It'll be interesting to see how the NCRS judges originality in a few years when ZR-1's are eligible for their shows. I suspect there are a lot of date codes that should at least make sense shuch as a '92 built LT-5 in a '90 but that might be all they could do.
90 KOTH is offline   Reply With Quote
Old 07-24-2003, 05:00 PM   #4
65ZR1
CF Senior Member
65ZR1's Avatar
Default Re: Matching #'s? (90 KOTH)
Chassis serial is located on the vertical pad right beside the bellhousing. passenger side I think.
65ZR1 is offline   Reply With Quote
Old 07-24-2003, 11:29 PM   #5
90 Corvette ZR-1
CF Senior Member
90 Corvette ZR-1's Avatar
Send a message via AIM to 90 Corvette ZR-1
Believe me we are having a "ball" with all the electronics.
90 Corvette ZR-1 is offline   Reply With Quote
Reload this Page Matching #'s?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
'64-Premium on Matching #'s? but it's automatic :( coolstuff C1 & C2 Corvettes 13 06-28-2005 05:03 PM
Will matching #s on a C4 ever be an issue? gpagaduan C4 General Discussion 36 05-17-2002 10:10 PM
Are matching #'s that big a deal? LABulldog C3 Tech/Performance 44 03-12-2002 07:49 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
