C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
oil cooler not working?
Old 07-06-2003, 08:53 PM
FastMatt2
FastMatt2's Avatar
Default oil cooler not working?
Is there a way to test if the Stat is opening? Yesterday I got in a race with a C5 on the HW in my 94 ZR-1, and I pulled it up to 180, when I let off and looked down my "check gauges" light was on, and my oil temp was nearly maxed out. I clicked the gages button to pull up what the Oil temp was and it was 272deg! Water temp was only 208 deg . It was about 110deg out side. I put it in 6th and drove at 75mph, and it took almost 20 min for it to drop to 230deg… (I’m running 15W50 Mobil 1)
With the size of the oil cooler I would think the oil would not get near that hot.
do I just need to up-grade the oil cooler for this NM heat?
Old 07-06-2003, 08:55 PM
Bans25
Bans25's Avatar
Default Re: oil cooler not working? (FastMatt2)
Wow... I wonder if the sensor is getting wacky?
Old 07-06-2003, 09:16 PM
ZR-1DUDE
ZR-1DUDE's Avatar
Default Happens to me also
I put a Fluidyne cooler in and it didnt' fix it. 1994 #103 - Was running a 911 the other day and had the engine in high RPMS for 10 minutes or so - same check gauges and the secondaries kick out. What serial number is your ZR-1?
Of course in Dallas, it is pretty hot. I am thinking of just driving the ZR-1 in the winter and putting it up for the summer.
D.
Old 07-06-2003, 09:22 PM
FastMatt2
FastMatt2's Avatar
Default Re: Happens to me also (ZR-1DUDE)
How do I know what # ZR-1 I have? is there a way to cross ref the VIN # or something?
did the larger cooler help at all? How On earth did thy run these things for 24hrs at WOT?? less thy found a place were it was night , and 70deg out for 24hrs lolol
At night I have never had it go near this high.
the thing I really find funny is that my the 94 LT-1 vet I had you could run flat your for as long as you wanted and the oil temp never went over 250ish. and it has less oil, and no oil cooler.
[Modified by FastMatt2, 2:29 AM 7/7/2003]
Old 07-06-2003, 09:33 PM
90 Corvette ZR-1
90 Corvette ZR-1's Avatar
Default Re: Happens to me also (FastMatt2)
The number of the car is the last 4 digits of the VIN
Old 07-06-2003, 09:35 PM
ZR-1DUDE
ZR-1DUDE's Avatar
Don't get me to lying. I have the fluidyne radiator and oil cooler - didnt' fix it. It is better, but not as good as my z06. Brian says I just beat the pine tar out of it too much...
D.
Old 07-06-2003, 09:39 PM
FastMatt2
FastMatt2's Avatar
Default Re: Happens to me also (90 Corvette ZR-1)
cool, I have #207 then:)
Old 07-06-2003, 10:17 PM
xsmph
xsmph's Avatar
i dont think that is normal, i have never seen my gage on my 90 go past the mid point on worse case scenarios. During racing is just at 1/3 of the total read out.. it is either the gage sensor, or the thermo on the oil filter housing....
I see the water temp hotter than the oil temp in mine all the time.... around 20 deg. more ...
[Modified by xsmph, 9:19 PM 7/6/2003]
Old 07-06-2003, 10:36 PM
The Lurker
The Lurker's Avatar
Default Re: Happens to me also (xsmph)
Could it be that the oil, much like the water, kinda goes into bypassmode under high RPM situations? Perhaps, the whole cooler, even filter, may be not "needed" under high pressure, high RPM situations? Ah-ehm, you may want to check the operation of the cooler valves and how they work.
Old 07-07-2003, 12:18 AM
FastMatt2
FastMatt2's Avatar
what are the part #'s for the fluidyne radiator and oil cooler, i'm going to order them.
Old 07-07-2003, 07:59 AM
Tyler Townsley
Tyler Townsley's Avatar
Default Re: Happens to me also (The Lurker)
What he is really trying to say is if you have a stock thermostat you have no water flow through the radiator starting at 5200 and by 5800 it all goes around the radiator straight back into the block. If you don't do something about this all no aftermarket radiator is going to help.
When the water gets really hot the temp guage is inaccurate because the sensor sees more air than water.
Tyler
[Modified by Tyler Townsley, 8:02 AM 7/7/2003]
Old 07-07-2003, 11:03 AM
ZR-1DUDE
ZR-1DUDE's Avatar
Default Thermostate
So - do I buy another thermostate, take it out, or drill it?
They say they test the ZR-1 out in deather valley, etc - they need to do it in FLA or TX for the real test. :-)
Tyler,
What else have you done to yours to make it run cooler?
D.
Old 07-07-2003, 11:37 AM
ShawnZR-1
ShawnZR-1's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
There was a very interesting e-mail thread on the ZR-1.net a few months ago about this very same subject. From what I gathered (and there was a ton of reading and mis-information), there is a valve in the thermostat housing that re-directs the flow of the coolant simply because the radiator couldn't handle the pressure and flow at such high RPM's. But that raises the more important question that you already asked: How in the world can you run the car at 6500 rpm for 24 hours??? Something has to be modified.
Now, more to your original question of the oil temp going through the roof. I'd say something isn't flowing correctly. When I had my beast on the road course, my water temps would spike at 260*+ but oil temps didn't get too far above 250. I was running between second and third gear always above 3500 rpm (gotta keep those secondaries open!). I'd be WOT through 2nd right up to 7200 then to third again up to 7000, brake for the turn, feather, WOT, rinse, repeat. 12 turn course.
Old 07-07-2003, 11:49 AM
ZR WON
ZR WON's Avatar
Default Re: oil cooler not working? (ShawnZR-1)
Shawn:
It was modified.. The car had 3.07 gears and was turning right at 5800RPM as I recall. My guess, right before the coolant bypass completely cut off water to the radiator. Also, it wasn't very hot outside when they made the record run so just a little water into the radiator might have been enough to keep it cooler?!?!? Very interesting
Old 07-07-2003, 11:50 AM
Tyler Townsley
I asked Tommy that same question and his answer was 'Huh? Didnt know that'. Bottom line they got lucky. Outside temps were near freezing and they limited it to 5700 rpm max which allowed enough water flow to keep it cool
If I were to do events with the ZR1 like you guys are doing I would go to an aftermarket radiator that will handle at least 100 gpm and cut the large spring in the thermo which allows water flow all the time(the small spring is for the bypass). In winter use a cardboard cutout to block the radiator for heat or switch back to stock thermo. You have to have a thermo in the system . If and only if you cut the large spring in the therm you can use a 1 in pvc plug to block the bypass route. Never try to use a cut thermo in a stock system its taking a chance you do not need take.
Max HP in a ZR1 occurs at a 157 to 165 deg water temp.
Tyler
PS There are many threads on this problem in the archives.
Old 07-07-2003, 11:53 AM
ZR WON
ZR WON's Avatar
Default Re: oil cooler not working? (Tyler Townsley)
Tyler:
What do you mean, "Cut the large Spring?" Cut it in what way???
Old 07-07-2003, 12:57 PM
ZR1 MK
ZR1 MK's Avatar
I have the Fluidyne stacked 3 row radiator and 4 row oil cooler. The radiator comes in 4 row version, but restricts airflow more than 3 row. With a/c condener in front of radiator, I choose the 3 row unit. I'm planning on trying a 1" plug with 3/8" to 1/2" hole rather than eliminate the bypass entirely. What about the thermostats that have 9 lb vs 5 lb of spring pressure built into them for bypass opening?
Mike
To oil cooler not working?
Old 07-07-2003, 03:05 PM
Tyler Townsley
Default Re: oil cooler not working? (ZR WON)
Take a dremell tool and cut it out so the thermo is open all the time.
Do not mess with the bypass unless you are very careful. The system depends on the bypass when its cold to route water to the thermo so it can function. If it is closed and you have restricted the bypass you could be trying to force 90+ gpm through that restriction and that will blow the radiator. Also the motor will get hot faster than the thermo will open in a restricted setup.
http://temp.corvetteforum.net/clubs/tyler//thermo.jpg
BTW the system was designed by a GM engineeer and it is more complex than first glance would suggest.
Tyler
[Modified by Tyler Townsley, 3:22 PM 7/7/2003]
Old 07-07-2003, 05:07 PM
The Lurker
The Lurker's Avatar
The oil cooler also gets bypassed in high RPM operations. Have fun.
Old 07-07-2003, 05:23 PM
FastMatt2
FastMatt2's Avatar
Default Re: oil cooler not working? (The Lurker)
what it the point of a oil cooler if it get's shut off when you need it?
Quick Reply: oil cooler not working?
