Motor mount wraps touching headers and an interesting find
I wanted to see if anyone else has experienced this interference issue. While under the car today, I noticed the factory reflective heat wraps were in contact with the headers on the driver side. I’m curious to know what others have done to resolve this if you’ve had the same issue. It’s pretty dense, tightly packed stuff around the motor mounts, so I don’t think there’s much room for “tightening” the wraps. Also not a lot of room for hands.
And now for something that may be common knowledge for some or maybe it’s just coincidence. I happened to be looking at the right area at the right time and I noticed my oil pan has “ZTK” on the side of the mounting flange on the driver side. Granted, it is at the end of a series of numbers, but I wondered if this was ZR-1/ZR1 specific alphabet jargon. May just be coincidence.
The alpha-numeric stampings are actually on the lower crankcase rail that the oil pan attaches to. That series of characters is the Mercury Marine SN. De-coded, provides the date the engine was assembled and its order in the number of engines assembled on that date.
The following 3 users liked this post by A26B:
The following 4 users liked this post by HAWAIIZR-1:
Forgive me if my memory is off. When I rebuilt my motor in 2010, the insulation was coming unwrapped so I recovered them. One of them was cracked too so it needed replacement anyway. If I’m not mistaken you can remove the K support despite is seems like it holds up the motor it does not. You can lift your motor and remove the motor mount to inspect/replace if needed and do similar.
Thank you for the information, Jerry! It’s always nice to learn a little more about these cars.
Thanks for the information on this. As far as lifting the motor: I’ve wondered the best way to do this without damaging anything. I actually have LT5 specific engine lifting brackets.
LT1 engine mounts - CorvetteForum - Chevrolet Corvette Forum Discussion
replacing motor mounts on lt1? - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
