How many ZR-1’s have working secondaries (in 2022)
on a smaller engine with a closer to stock secondary port size, I've heard they cost about 6 cfm from the blade in the airstream
on my 390 LSV only picked up 6 ft lbs and I suspect that was from tuning. Ask Graham what he recommends, he's the man and won't steer you wrong
Now I've maxed out the port, we'll see how much it picks up. The secondary flapper are not much at all of a restriction if they open fully
Sounds about right, Ron. When I determined my horsepower goals, I felt like 630hp, 530rwhp, would be near the limit for drag radials on the street, and realistic with my current porting. Anything beyond that would be difficult to hook up and cost exponential $ for little return, so I've been trying to stay somewhat pragmatic about it. Time is also a consideration, and more porting delays the project.
Mine still work on my 95. When I swap out the top end for ported this summer I’ll check everything and replace parts as needed. I know that little check valve has been leaking for years so I’ll finally get to it. No plans to delete.
Mine worked on the 1991, however the passenger side actuator gave up working. I was able to find a replacement thanks to Paul Workman. IF there was a reliable supply of actuators, I would’ve considered keeping them. However, when I removed my butterflies, the valves were CAKED with deposits. The primary valves were all nice and clean. I actually drive the car as intended and got into the secondaries opening for some 6 to 7K rpm runs at least once every drive. Even with that, the secondaries still cake up it seems.
I loved the dual mode aspect about the ZR-1 and always will, but after seeing the valves, I don’t miss it. It didn’t help that she already had the secondaries modified in the chip to always be on regardless of key position when I took ownership. Now if I had kept the entire vehicle all stock that would be a different matter. I chose to go after headers, 3.90 rear gear, top end porting and an aluminum flywheel.
One day I will have the engine rebuilt to a 368 and at that level, Marc or his son would probably recommend deleting the secondary throttles anyway. I think they’re great for a stock application. Once you start chasing performance, I don’t think one will miss them.
1993C4LT1 (05-25-2022)
A little motivation for you. Not sure if you have read up on this build.
http://zr1.net/forum/showthread.php?t=32002
mine would function if i had not wired them open. i left them like that in case of resell.
the racecar build, they be gone!
1993C4LT1 (07-17-2022)
#33
tl;dr - no secondaries for me
Just got my 94 a few weeks ago. I noticed this electrical connector not connected to anything. After reading some of the Haibeck literature, I see it's the vacuum pump for the secondaries. Plug in the connector, and the pump runs continuously. Since the car runs fine, this must mean the secondaries have been eliminated, and I have an aftermarket chip in my ECM.
#39
I have a 91, the secondary's work and still installed, but I have mark's chip and safety wired them open. Even the vacuum pump still works/runs. Very easy to go back to stock.
