Chip Burner For A ZR1
NCM Lifetime # 982
I know that I ran this question before. I need to get my hand's on a GOOD complete chip burning equiptment for a ZR1.
TIA :seeya
TIA :seeya
Re: Chip Burner For A ZR1 (FrankUrbinati)
Well What I suggest for complete DIY PROM burning:
Some sort of Scanning software (DIACOM, EASE, Datamaster, ETC)
Tunercat PROM editing software with the correct TDF (tunercat Definition File) for your ZR1 ($80 plus $20 for the Def. file)
PROM Programmer.. the Pocket Programmer http://www.xtronics.com I have heard good things about and is only $150. I also believ it will work with Win2K and XP. At some point that will be the programmer I buy to replace my old Needhams PB10.
BTW, I have used Tunercat for two of my friends 91 ZR1s along with another friend's 94 ZR1 and of course for my L98. It works really well
Hope this helps
EDIT= I forgot you will also need a UV eraser if you plan on using 27C256 PROMs. or you could buy the Craig Moates adapter and use the 29C256 EEPROMS
[Modified by -=Jeff=-, 11:35 AM 12/31/2002]
Hope this helps
NCM Lifetime # 982
Re: Chip Burner For A ZR1 (-=Jeff=-)
Scanning, not a problem.
Do I need Both the Tunercat and the Pocket programmer ?
Yes, Tunercat is what you use to change the parameters, and generate the bin file. The pocket programer is what you will use to "Burn" the image on the EEPROM.
What are you using for scanning, and how do you like it for the LT5?
(I do not have a scanner yet, and have only used diacom in the past..)
NCM Lifetime # 982
Re: Chip Burner For A ZR1 (Bans25)
Bill , I am using a Diacom unit. Easy to use and I have used it with other car's before (turbo Buick's).
Anyone got a link for tunercat ?
TIA :seeya
TIA :seeya
http://www.tunercat.com
You can also download the editor for a 30 day trial..
and like Bans said.. the tunercat changes the file, a pocket programmer puts it on the PROM
