New ZR-1 owner, but not new to CF
Hello all!
A week and a half ago I bought this car online and had it trucked down from Michigan to Texas:
https://nostalgicmotoringltd.com/veh...rolet-corvette
I also joined and posted a bit of a lengthy introduction on ZR1.net:
https://www.zr1.net/forum/showthread.php?t=31897
While I'm new to C4 ZR-1 ownership, I'm not new to Corvetteforum - I've had a C7 as my daily driver for almost 3 years now. Here's a pic of both of them in the garage - I need to get some better beauty shots of the two and maybe do something about the poster behind the Z, lol...
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Grats and welcome to ZR-1 ownership.
ram_g (06-30-2020)
Around the block at low speed - great, lol. Haven't really exercised the car because the tires are original and while they hold air, they do have many cracks. I have an appointment for new tires tomorrow morning, and will hopefully have a spirited drive back home.
At the moment the main issue I am watching is a slight weeping of coolant from the plenum gasket on the driver side. There was a plenum bolt flat out missing from this area so I put one on and torqued the others to spec (some were loose). The coolant seep seems to be slowed but is still there. Will watch to see if it remains slight and then maybe trigger a plenum pull and elimination of TB coolant which should solve the problem once and for all (with an internal plug of the IH / plenum coolant passage). But I will probably wait to gain more experience with the car to assess what else I should do, if anything, when the plenum is off. (Or if I can simply kick the plenum pull down the road some.)
Congrats!
Well Done, I just picked mine up a few weeks ago #285 1992 ZR1 42K miles, black interior, was outside of Houston, after a stop in Austin and Plano I drove it back to Colorado!
