C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Any way to do a reverse GM part number lookup?
Old 11-27-2002, 11:35 AM
Bans25
Bans25's Avatar
Default Any way to do a reverse GM part number lookup?
I have a GM ZR1 part number, is there any way do a reverse lookup?
g-m parts direct does not recognize the number..
thanks
-Bill
The number is 14104646, its supposedly a power key lock cylinder but I am unsure of what year it will fit (I am looking for a 1990)
[Modified by Bans25, 11:36 AM 11/27/2002]
Old 11-27-2002, 12:16 PM
A26B
A26B's Avatar
Default Re: Any way to do a reverse GM part number lookup? (Bans25)
I've bought from these folks before and been very satisfied with the entire transaction. Notice there is a place for you to put in the OEM part number for lookup. Be aware that GM is prone to change numbers and the lookup might not return anything. Give them a call as they are very helpful. http://www.parts.com/index.cfm?actio...nt&sfid=213835
Good luck!
Old 11-27-2002, 01:00 PM
dgoodhue
dgoodhue's Avatar
If you email Jeff Kopp, he can give the new number and brief part description or if its discontinued.
Old 11-27-2002, 03:13 PM
454Big
454Big's Avatar
Default Re: Any way to do a reverse GM part number lookup? (dgoodhue)
Check this link : http://www.{Non-supporting vendor}.com/results.cfm
If you enter your part no it will give you this:
Old 11-27-2002, 04:11 PM
LIMEY
LIMEY's Avatar
Sadly,
GM Discontinued that part #, But I do have one in stock, $75.00 if you want it.
Kurt.
http://www.whiteracingproducts.com
Old 11-27-2002, 04:20 PM
Bans25
Bans25's Avatar
Default Re: Any way to do a reverse GM part number lookup? (LIMEY)
Sadly,
Kurt.
So its for a 90'?
-Bill
Old 11-27-2002, 04:26 PM
LIMEY
LIMEY's Avatar
Part # 14104646 1990 LT5 Power Key Switch.
That's what I have stock of.
Kurt.
To Any way to do a reverse GM part number lookup?
Quick Reply: Any way to do a reverse GM part number lookup?
