Non ethanol gas
Zen Vet Master Level VII
I stay away from ethanol. Your engine will be happier with real gasoline that it was designed to use.
Octane doesn't directly affect wear on all the parts, in the same way fuel additives do. Octane impedes "knock which allows more spark advance which yields better engine performance. Uncontrolled detonation can/will cause severe engine damage.
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
I'm lucky that I have several stations nearby that sell ethanol-free premium. I do try to use that, although I run E10 many times too. The last several fill-ups before putting her to bed in the Fall, I do put in ethanol free. I don't know if it is better or really helps, but I feel better about it
I just got my 90 ZR1 last fall, my first Vette. I have been in auto repair all my life and am learning some of the intricacies of this car. I have a few other early high compression flat tapped cars and use 93 octane with some ethanol in it (10-15%) and add octane boost with lead additive. I also use Valvoline Racing oil with Zinc in all of them. Is this a good combo for my Z? The car has 45K and runs good with the previous owner having installed Bosch injectors. What is the best weight and type oil to run, the Valvoline Racing or something else?
I'd consider installing his engine intake duct support hoops, throttle body coolant bypass line and performance chip. These are simple and effective ways to get the most out of your car.
