Forgelines and Carbon ZR-1 brakes
Received 1,872 Likes
Not a bad price on these used fronts. https://www.corvetteforum.com/forums...nd-rotors.html
Amazing... well done. Were you at Carlisle last year before these latest mods? I feel like I saw your car.
Awesome job. I recall Pumba doing this several years ago with a C5Z and doing a big write up about it. If I recall he is/was an engineer with GM or had someone with him that was. What I remember the most was that he had to redo all the suspension because the knuckles were not strong enough to handle the loads the brakes could exert on them. Not saying you will have an issue but its worth a search over in the C5 part for it.
#33
Here is what he did and why. https://www.corvetteforum.com/forums...s-inquiry.html
#35
Pumba
Pumba and I emailed back and forth a few times. My car is more about the show and rarity than race track performance. I do drive my car but I don't want to subject the paint to hard track days. Thanks for the input!
#37
C6 Z06 brake rotors are 14" front and 13.4" rear. The carbon C6 ZR1 rotors are 15.5" front and 15" rear.
henryr (02-25-2019)
#39
so if i am googling correctly....
the zr1 CF brake rotors should fit over 18" wheels assuming offsets are correct ?
i found a set of 18"/19" wheels i think they call the Cup versions of an anniversary 427
#40
Cup wheels were exclusively 19"/20", so you may be looking at replicas. C6 ZR1 rotors typically need 19" wheels up front to clear, though there are a couple of 18's that will fit.
henryr (03-03-2019)
