C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Fixing that pesky header stud oil leak.
Old 11-27-2014, 11:14 AM
Z51JEFF
Z51JEFF's Avatar
Default Fixing that pesky header stud oil leak.
Ive got the car apart for some detail cleaning and figured Id fix the header stud oil leak while Ive got it apart,any tips and which stud is the one that leaks,is it both sides of the block or only one side?Thanks.
Old 12-02-2014, 06:56 PM
Paul Workman
Paul Workman's Avatar
It is the center stud, separate from the flange bolts. It is between the 3-5 and the 2-4 exhaust tubes, if memory serves, and NOT the flanges themselves.
I used some RED RTV on the threads. Hasn't leaked a drop in 5 years now...
Old 12-04-2014, 05:16 AM
Z51JEFF
Z51JEFF's Avatar
Thanks Paul. Is the leak-leaks limited to these areas alone or is it throughout all of the header studs?
Old 12-04-2014, 04:17 PM
Dynomite
Support Corvetteforum!
Dynomite's Avatar
That stud that Paul refers to appears the ONLY stud (one each side) that is threaded into the Oil Return Passage Way.
That would be zero pressure oil flowing from top of heads down to oil pan.
Fixing Oil Leaks on the LT5 Engine by Marc Haibeck
Old 10-10-2023, 04:23 PM
dakleenupman
dakleenupman's Avatar
St. Jude Donor '16
crazy long time ago but would anyone have the dimensions of the header stud? Thread pitch? I’m putting together my 91 and am missing these.
chris
Old 10-10-2023, 06:09 PM
WVZR-1
WVZR-1's Avatar
Received 2,268 Likes on 2,029 Posts
M8-1.25 for thread and what you buy and use is very dependent upon the flange thickness. Very early studs in the OE were nearly 40mm long with about a 5mm shoulder in the center,
***** Well it appears that the stud in question might actually be 3/8-16 (see post #11) BUT the balance of the hardware converter to cylinder head is M8-1.25 x whatever length required.
Old 10-10-2023, 07:02 PM
A26B
A26B's Avatar
Old 10-10-2023, 07:19 PM
WVZR-1
WVZR-1's Avatar
Originally Posted by A26B
Those are Metric CM/mm increments?
Old 10-11-2023, 01:49 PM
A26B
A26B's Avatar
Yes (10 minor divisions/major)
Old 10-12-2023, 11:11 PM
KOZ
KOZ's Avatar
Did you just double nut it to get them out?
Old 10-13-2023, 08:32 AM
A26B
A26B's Avatar
The studs I have, all came from 375Hp engines (90~92). The threads are 3/8-16.
Old 10-13-2023, 08:34 AM
A26B
A26B's Avatar
Sometimes, but most come out with the locking nut.
Old 10-13-2023, 09:14 AM
WVZR-1
WVZR-1's Avatar
That's interesting for sure
To Fixing that pesky header stud oil leak.
Quick Reply: Fixing that pesky header stud oil leak.
