1993 ZR-1 HP & Torque
You missed the point...torque under the curve is completely different from torque at 1000 RPM. The LT5 is not your typical DOHC engine with very low torque at low RPM, quite the opposite actually. As stated, it makes more torque at 1000 RPM than the L98 and certainly more than the LT1. I have no problem cruising at 25 MPH in 6th gear with my ZR-1 where itīs doing a little over 500 RPM...itīll even accelerate from that speed/RPM with no problem.
I'm sorry but considering that 6th gear is a double overdrive (for lack of a better expression) , I'm not sure how what that example is supposed to suggest..............nor do I see when that particular action could ever be interpreted to be a "good" idea.
The speed limit in my old neighborhood was 25 MPH and strictly enforced. Since I had about 2 miles of that, I would put it in 6th and cruise. I don't understand why you can't see it as the "best" idea...why would you ever consider it to be a bad idea?
Gears are typically used to multiply engine torque but as you pointed out, 6th gear is a double overdrive which means it divides engine torque to the rear wheels, in half to be exact. That's a perfect example of how the LT5 makes very good torque at low RPM.
Received 1,864 Likes
I agree with Brad and dtana. I would never abuse my ZR-1 that way,either. Just because you can do something,doesn't mean you should.
Pro Mechanic
The title, "high performance sports car" (A title that you created there) doesn't change what the car can and can not do. Most Corvettes have what is basically a truck engine, in them. That "title" doesn't change anything either. The engines (all engines) in C4's are perfectly happy/willing/able to loaf along at very low RPM in a high gear w/no ill effects. As long as the motor is running high enough to make enough oil pressure, where is the harm? There is none.
Second, GS didn't say he was at WOT @ 25mph in 6th. I run my C4 through my neighbor hood in 6th too....25 mph speed limit. I'm not touching the throttle. Engine is basically idling, only it's doing so, in gear. Wife's CTS-V (LS6) will do it too. Heck...even my factory carb'ed '83 Trans Am would go down to 28 mph/900 RPM, locked up in O/D -Even up hills! Sold that car w/245k on it, so...
As long as there is sufficient oil pressure, the engine won't "care" what RPM it's turning. the "problem" of "lugging" in this day and age, is not a mechanical problem....it's a psychological one.
(advanced electronic controls w/ feedback). Engines are so highly controlled now, lugging will not result in pinging, A/F ratio issues, bucking, etc.
And I guarantee nothing is mechanically wrong with the car!
Pro Mechanic
Pro Mechanic
I would be willing to bet either one of you my car is perfecto!
The car will be at the 2015 Denver NCRS National Convention for either of you to observe and critique.
#33
You can talk all you want,Tom,but we will just have to agree to disagree about this topic. I don't really give a damn what anyone else thinks because I'm not going to try to drive my car at 25mph,in 6th gear.
Also,the LT5 was never designed for a truck application.
#34
Pro Mechanic
Right. You'll note that what I said was;
"Most Corvettes have what is basically a truck engine"
See the "most" part? Doesn't really matter though b/c again, we're using "titles" which I attempted to dismiss. Fundamentally, the LT5 operates the same as the L98 or any any other GM V8 except that it's even more robust and better controlled than it's contemporary peers.
Enlighten yourself. There is good technically correct info being given here. Drive your car the way you want to, but you can learn something in the process.
#35
Pro Mechanic
So how does GS's car drive at low RPM then? How does my ratty, low-tech, pushrod LT1 manage to do it? Surely, the LT1 is not more refined than an LT5...
I'm sure your car is spectacular. But it should be able to run smooth down that low.
#36
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Just got back from a long drive in the 93, 3.45 gears, I tried as slow as I could get comfortably in 6th was around 35mph. I would never do this on a regular bases as it felt like I was lugging it very hard, now 5th was fine at low speeds. I like to stay in 3rd for 30+mph, 4th 40+mph etc.
#37
Just as Clint said I would not recommend doing this in an LT5. I have done this by accident only.
Steve just verified for you, and I promise that 93 car does not have any problem's.
#38
Pro Mechanic
What RPM do you consider to be "OK with the engine", to go to WOT?
Below which, there would be engine damage?
#39
Pro Mechanic
#40
St. Jude Donor '16
I would go WOT from idle 775 in 1st of coarse but would just get a lot of wheel spin.
Next I will try it with the 91 500hp and 3.73 gears
