91 new injector stumble when warm
Here I thought I was going to have to spend the next couple weeks trying to troubleshoot why after changing to new FIC injectors my 91 developed a stumble once warm. I was looking for vacuum leaks, thinking maybe one of the new injectors was bad. Guessing that maybe a coil had gone bad.. MAP sensor failed. but after reading all the threads and possible causes, I went out and stared at the engine compartment checked and rechecked the driver side, all good. Checked the passenger side. all was looking in order until I got to the #8 spark plug boot sticking over an inch out of the hole. I knew I had used dialectric grease in all the boots, but apparently not pushing #8 plug wire down the last inch and snapping into place could be the cause. Took her for a spin right after and all is well. Sometimes its the little things
Don
Don
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Yep, also you may want to put some dielectric grease on the boots.
