What kind of cash are we talking on a 380? ballpark, I have been throwing ideas around. what is the average hp on a 380, I assume 500+.
Even with doing the build yourself, all the machine work and parts will still run you close to $10 grand. If your going to do the motor in your car, then you have the additional downtime of your car being side-lined. Buying one done is not bad advice.
Rich
I agree, funny when I bought mine I was like , psshhhh I don't need a stroker motor, I did not for one second believe I was going to mod the car. My 91' Z28 was the punishment car that's why I put a built LS motor in it, well not the case. Another question where do you guys recomend I find parts for the LT5 engine build?? Pistons, crank, etc. I also think maybe a piston swap 9.1 comp. and Hendersons TT setup would be a nasty bastard. Not sure if 5 psi and a stock motor with 11.1 will be worth the trouble, nice to have some hard numbers.
Easy for you guys to say, you have killer cars done already but I do agree with you. problem is not to many strokers up for sale that most or I can afford.
