C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Maximizer Exhaust System??
Old 03-23-2014, 06:35 PM
Need4Speed90
Need4Speed90's Avatar
Default Maximizer Exhaust System??
anyone install this? thinking about purchasing it but havnt heard any exhaust clips or anything.
Maximizer Exhaust System for 1990-1995 Corvette C4 ZR1
This Exhaust will Increase Better/Smoother Exhaust Flow At Higher RPM To Generate More Power And Maximum Performance Out Of Your Engine. Great Power Package to Unleashed Hidden Ponies From Your Motor. Get Up To 35% Better Exhaust Gas Flow By Replacing The Restrictive And Inefficient Factory Exhaust With These Precision Mandrel Bend, Built High Flow Exhaust. 100 % Fitment, Great Quality And Lowest Price Guaranteed.
Pipe Diameter: 2.50"
Runner Wall Thickness: 1.5mm (16 gauge)
Product:
Maximizer High Performance Racing Exhaust System
Application:
1990-1995 Corvette 5.7L C4 ZR1 LT5
Features:
• Cat-back system fits all 1990 1991 1992 1993 1994 1995 Corvette C4 ZR1 LT5 Models
• Straight through 2.5" mandrel bend nonrestrictive design maximizes airflow and performance.
• Smooth mandrel bends pipes design increases exhaust flow up to 141% vs. stock
• Average increase of up to 14HP and 16 ft-lbs. of torque.
• High heat and weather resistant black powdered coated for the stealth look
• Deep acoustically throttle sounds exhaust give your Corvette the true performance sound without the annoying drone at low end and high end.
• Quad 3.5" double wall 15 ⁰ slant cut, high polished stainless steel sporty tips with dual rear exit design.
• All necessary components and hardware, including clamps are all included. Hangers are OEM prepositioned to ensure easy bolt-on installation. No welding or modification is required.
• Proudly designed and engineered in California U.S.A.
Old 03-23-2014, 11:37 PM
ghlkal
ghlkal's Avatar
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
I had never heard of it. When I looked it up, it looks similar to the OBX system (only in black) ...
Old 03-24-2014, 06:42 PM
secondchance
secondchance's Avatar
I agree. Looks just like OBX except in black.
I tested OBX system, with a help from another WAZOO member, about 2 years ago. Hooked up a pressure gauge to O2 bung and drove with 94 factory system followed by OBX. At 2000 RPM, factory system registered 1.4 psi and OBX registered 1.0 psi. Sound wise, more deep mellow sound as opposed to more raspy sound from Corsa.
I have been running OBX for about 2 years and have no complaint.
I recommend using Torca clamps. Clamps supplied with the OBX were not very good - bolts sheered off while torquing.
Old 03-25-2014, 11:43 AM
Graybeard ZR1
Graybeard ZR1's Avatar
The words "Maximum Performance" describing 2 1/2" pipe is a contradiction.
That size pipe cannot flow as much air as a 3" system.
To Maximizer Exhaust System??
Quick Reply: Maximizer Exhaust System??
