Question
Question
Could someone tell me what this part is. I was looking at my 95 Z and saw it but it's not on my 91 Z.
It's own the front drivers side next to vacuum canister.
It adds air to the exhaust so that the cats will heat up faster and work sooner. I pulled the fuse to mine: I think that by adding air to the exhaust the O2 sensors get fooled and the engine then runs rich, which is why I suspect all the smoke from the exhaust when you first put your right foot down.
The pump only runs for about 90 seconds to two minutes at first start in the morning- maybe a bit longer if the engine is really cool. If you have headers w/ air injection, you will get backfires until the air inj event ceases. I pulled the plug on the air pump until I had catalysts re-installed.
