415 to 441
415 to 441
Hi all, I've been hearing a lot of the increased cubic inches. What is the deal going from a 415 to 441? All aspects as it is something I might be interested in at a later date.
Also using a "closed deck" design developed by AES.
http://aesracing.net/product_info_lt5.htm
There are 2 441s here as part of the FBI along w a 427. They all run 10's.
Are there any durability or balancing issues ?
NCM Lifetime # 982
Psst......go for an econo-stroker.
side loading and balance issues aren't worth the extra cubes
I think a big bore short stroke lt5 would be both more efficient and more durable
a 427 sounds good to me
In theory, more cubes = more power. In practice, a max port 415 makes the same power as a 427 and as a 441. I had aspirations of upgrading my 415 at one point, but having lived with 585 rwhp, I realized that this is a ton of hp for a street driven automobile, and the projected power gain was minimal at best.
Finally - no matter what the cubic inches, make sure you have the compression that the engine can handle - at LEAST 12:1, if not 12.5:1. These motors make huge power and with the efficiency of the combustion chamber, the LT5 can handle a ton of compression.
Have fun Cliff!
Have fun Cliff!
Sam
NCM Lifetime # 982
Have fun Cliff!
Have fun Cliff!
When my engine was assembled, I went big on all counts. I've got stage IIIs intake and exhaust. If I were to do it again, I'd do what Frank is doing - 441 cubes, big compression, Stage III intake and Stage II exhaust. Having said that, my engine pulls like a freaking freight train to 7600 rpm - absolutely NO drop if power to that rpm level, and if I were crazy enough to raise the redline, it would pull to 8000 rpm with no problem. It truly is an amazing engine - I really love listening to it sing!
My 415 is 12:1, which is very common for a built motor. All the 368s/385s/402s/415s that I know of run 12:1, and knock is simply not an issue. I know of another 415 that ran 12.5:1, and it made big numbers too. Are there risks? Sure - I got some bad gas on the way back from BG a few years back and popped both head gaskets - no big deal - I pulled the motor and replaced 'em both. Always use name-brand gasoline!!!
I would suppose that with greater compression you'll need less advance.
NCM Lifetime # 982
A little alcohol-water injection at WOT will cure most detonation and pick up a few more H/P during the process
Oh econo-stroker , see Robert (Polo1)
