Recently replaced injectors, now quite fumey.
I recently replaced the old stock 23 year old injectors on my 415. Car is running well, except it is now letting out a high amount of fuel fumes.
I've pulled the plugs and all except one look to be burning very well. One is looking a bit sooty.
Question, did the engine just get used to the old injectors and now need setting up with a tech 2? (is that what they use)
A friend has a scanner and once he is back off holiday we will connect the scan to see what is happening.
Or could it be a sensor or something else blocked.
The engine should have plenty of air getting in as it has had maximum porting, runs headers and 3" B&B
Thanks in advance.
Thanks in advance.
Interchangeability
You 1991 charcoal canister is under passenger side behind rear wheel panel.
This little difference between 1990s and 1991s makes the Plenums not interchangeable (unless you want to plug and create different vacuum ports) but Heads, Injector Housings are interchangeable. And even mixable (1990 Heads on 1991) with some minor modifications to Injector Housings PCV.
have the injectors been sitting a while or are they new? sounds like that one cyl might have an injector hanging up. what brand of injector and what is the rated flow (lbs). unfortunately new doesn't always mean "good" might have a cantankerous one in there.
also check that they aren't leaking. you can pressurize the fuel system and pinch the return hose with vice grips and see if it holds pressure
o rings might not be seated properly. it's pretty tough getting them all to line up and go in right (took us 3 tries at gordon's school, but we got er dun)
good luck!
good luck!
If this is a 1990...then charcoal canister is under drivers side head light
This is a great thread as I guess all injectors do not deliver the same about of fuel with the same ECM commands.....maybe
I always wondered about that because no one ever asks what injectors are you using when you consider a custom CHIP
good luck!
good luck!
http://www.summitracing.com/parts/acc-150821
By the way it is a 90 car. When fitting the injectors I found the easiest way to clip them into the rail was the first ridge of the two. That way they were easier to push into the injector housings.
Think I might take the plenum off again and turn the ignition key to just before starting to see if there is any leaks. Also check to see if they are seated ok.
I always take my time and never rush things and thought they went 'home' OK. However practise does make perfect.
Thankyou all for your replies.
Injectors are new ACCEL Fuel Injectors 150821 and rated at 21 lbs/hr.
Gold cylon...you really seem to know your ZR1's! I just purchased a 95k mile 1990 that runs fine, a little rich though. What does the charcoal cannister do and can you replace the innards or do you have to replace the whole unit? someone also told me to replace the MAP sensor if it's the original, that a bad one will make it run rich also.
GC
NCM Lifetime # 982
OP: hook a fuel pressure gauge to the Schrader valve on the fuel rail. Then roll the ignition switch to ON, w/o starting the motor, and then turn it OFF. The pressure may spike, and then settle to mid to low 40s with the switch OFF. the pressure should hold to within a PSI for 10 minutes or so, long as the injectors (and the fuel pump check valves) are working.
And, having it scanned might shed some light on the O2s. (My scanner has paid for itself several times over - used on my Vettes and other vehicles too. Best tool in my box for troubleshooting.)
HTH,
P.
Thank you all for your input. A couple of things.
1/ I can not get hold of any AC Delco or Bosch 02 sensors without a wait. However I can obtain off the shelf (NGK)NTK OZA446-E8 Lambda sensors. Cross referenced from the Delco's and Bosch's.
Has anyone used these sensors?
2/ Not sure what a "Shrader valve" is although at a guess it's obviously on the fuel rail poking out of the Plenum area.
I don't have a fuel pressure guage, but have a vacuum kit in my possession. would this suffice ?
2. Yep right off the fuel rail on the passenger side
3. No you need a fuel pressure guage.
