Does your ZR "USE" any oil?
Forgive me again , im just chock full of questions. Does your zr1 "use" any oil between gas fill ups? Also what about adding oil between oil changes? Sorry to be a pest, its just that my zr is my new hobbie. Thanks again.
Keep in mind the '90 MY was not equipped with valve guide seals. It is not uncommon at all for a '90 to give a little puff of smoke on start up, so obviously they will burn/use a little oil. Also the PCV system on these cars is not ideal either. If I used too light of an oil in my old '90 it would use more oil. So use the recommended weight 10w-30, and expect some usage. The Lingenfelter doesn't use any.
