94 ZR1 Removing Transmission Help Please
This is specifically regarding the rubber shift boot BELOW the console trim plate. My question is do I have to remove any of the rubber boots to remove the transmission. Thanks in advance.
Have to: No. But it will pull it off when you drop tranny.
Remove
-battery ground cable from battery
-console door
-shift pattern, retaining pin, ****, reverse lockout
-shifter/console trim plate
-upper shift boot from tunnel (I've found it easier to just take acorn nuts off and remove upper boot totally)
-trans in 3rd
-remove MAP sensor and accordian intake duct from engine so tilting doesn't damage
-3 x electrical connectors on tranny
-bolts on tranny
Some steps simplified. Ask more if you need it.
Ted
Remove
-console door
-trans in 3rd
-bolts on tranny
Ted
Thank you so much! Exactly what we needed to know. we've read to put in 3rd gear? any idea why? On the way to replacing the clutch. Info much appreciated.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
The boot in the car stays, although sometimes it comes lose from where it passes through the body.
pic of inner boot
pic of shifter after it is removed (this is off trans) but what comes out with it.
pic of inner boot
Lube fork ball and trans input shaft where disk "floats"
Clean PP and flywheel friction surfaces with brake cleaner.
Symmetrically remove and tighten PP bolts
Bell housing removal requires sliding fork off ball before dropping bellhousing. Remember opposite to install.
Would replace pilot bushing. Pull with blind-hole puller.
St. Jude Donor '16
As Ted stated use a puller on the pilot bushing.
Do not use the old wet paper towels or grease method to remove as you may push out the oil crank seal used on the LT5 crank shaft.
Man U R awesome! Chuck says he owes U a brew We're half into this process so there may be more questions on our part. He asks if U might know of whereabouts of an original throw out bearing as opposed to an after market production. We understand they are almost impossible to find. Thank you so much for your assistance
Advice heeded, thank you
I'm running a Carolina clutch stage 2 in my track car and throw out has held up.
Ted
Don't ask me why I know this.....
