Admiral 94 comes home. Finally ! :). Let the mods begin !!
#561
[left]
I’ve been to downtown New York City in the 93 Lt1 vette years ago after a day at englishtoen New Jersey’s track for a GM high tech shootout.. I do recall the downtown area having potholes that I couldn’t believe. Having said that yes I need to be careful but I think you’re right in that our roads are quite decent around Ontario. Here’s my daily... just a recent pic with the summers on and ride height readjusted. It gets around everywhere without issue.. but these cars are quite high stock vs C4s. If I do get a Chance and budget permits I have 2 ideas that will completely change my exhaust setup anyways and both will likely increase clearance in the back.
Neither of your cars are suitable for suitable for New York City roads as they sit now. The wheel and tire combinations would not survive the pot holes.
5abivt (07-06-2018)
#562
Thanks ! The wheel and tire combination I would trust just as much as an oem wheel and even more so than say an oe wheels replica wheel or other china brand cast wheels. Its the ride height that would worry me and the bottom of the car.
#563
Quick update: Plenum is off and I sent the fuel pressure regulator out for a rebuild. I recorded a video and did a short 1 minute version for instagram. Still working on editing a clip for youtube.
1 min plenum pull (fast forwarded!) : https://www.youtube.com/watch?v=Ols5...ature=youtu.be
5abivt (07-06-2018)
#566
Been a long time since I updated and parts have been piled forever. I moved into our new place after almost 3 years of delays .. and started working on the garage to make it how I want before I bring the ZR-1 and the 93 home. Epoxied my floor (not epoxy but ‘polycuremine’ supposedly advertised as 20x stronger than epoxy) and have to finish the lower foundation and paint still and then the lighting. The goal was to diy and keep costs low as possible. I mean why would I pay someone to have anything done when the money could go towards a stroker build
few quick pics of fhe house and garage ...
The lot a few years ago..
Got most everything what I wanted in my home. No sidewalk , and facing south. The shade at just 2-3pm is fantastic. Looking forward to washing my car earlier in the day without having to deal with water drying and leaving water spots 😇
Few weeks ago. The biggest surprise was the garage doors.. I’m in love with them. I didn’t even know they were glass and light comes through <3
1993C4LT1 (10-08-2018)
#567
Few pics of getting the garage ready..
after pics.. went very light on the flake. Don’t want to be doing ‘where’s waldo’ On the floor when I drop a nut or bolt!
fancy pic
Certainly can’t wait to get pics of the z inside ... with the walls and ceiling painted and with all the new lighting (still to do)
fancy pic
#568
And back on topic. got the new custom modified fuel pressure regulator in. Absolutely love it. Rails are out of the way and am about to start pulling the injector housings for new gaskets and sealing... then to go down the list one by one ... new rad, cooling hoses, pcv hoses and fittings, oil cooler lines ... and much more ..
#569
Looks good. I just moved into a new home too, glad to have an over sized garage and extra wide door too. Can get both my Vettes in and still have room to work around etc.
#570
So jealous, two car garage lol.....Mine is a one car with no door.....That's what happens in community drives in NY.....Garage is too small for the Z, would have to extend garage to put a door on it which leaves no room to back car in..
Oh well...And to think the home is worth around 800K and its only a 2 bedroom attached.....The Big apple...Better have big pockets...
Anyway, great looking home...Enjoy it to the fullest....
#571
thanks guys ! it’s ddfinitely not the biggest.. I think depth wise my last home was deeper but it was a 1 -3/4 gaarage becasue the door cane into the garage making it only possible for a very small car to fit. In that case it worked for me as it left me a lot is space to work around the car. I tried to get the builder to give me a single door but they refused but I don’t mind the double doors since I plan (fingers crossed) to get a 4 post on one side so I can stack the C4s. With a 4 post a single door wouldn’t have been much more useful if any.
Sitting here draining coolant ... never seems to end out of this thing lol...
#575
The garage looks great! I love oversized doors--mine is a double door but it is 18' wide instead of the usual 16'. Critical to allow the lift to be left of centerline so wife has enough room. You don't seem to have that issue with two separate doors. When I put my lift in I had a garage door guy raise the tracks up to within about 6" of the ceiling so the cars would clear the open door when parked front end in. Also Installed a Liftmaster 3800 jackshaft opener so nothing in the middle of the ceiling. Works great. Looks like you have plenty of ceiling height for a lift-I have only 10' so my 5' tall car and my 4' tall car just fit with a couple inches to spare. Also put electrical outlets on the ceiling to power the opener, the lift and battery charger so they are not on the floor. And I love my Floorguard floor something like yours. Plenty more pics in my albums section if you need them. --Bob
Garage has an 18' wide door--really helpful because lift is actually iside the garage centerline and still has 22" on the side.
Liftmaster 3800
Liftmaster 3800
#577
Liftmaster 3800
Liftmaster 3800
Hey most guys don’t even have a garage it’s a workspace !
#579
Hi Jeff--
No, there is no lock on the door itself. (Below is a picture of the door closed). With a regular opener it pushes the door closed and holds it so you can't open it from the outside once closed. With a jackshaft opener you could arguably just lift it up when it is closed, so what they do is have a solenoid on the side that thrusts a 1/2" diameter steel locking pin into a hole in the track to prevent it from being opened. When you push a button or enter a code to open it, the pin slides back. Has worked fine for five years. --Bob
#580
Hi Jeff--
BTW, I work for Chamberlain (Liftmaster)
