1994 zr-1 stroker 402 fs
Putting my pristine 1994 Black on Gray ZR-1 up for sale. This car is beyond pristine. Still smells like new. I'm the second owner of this car, and I've put roughly 100 miles per year on it since purchase. This is the reason it is up for sale - I simply don't drive the beast!
1994 black on gray, 26,178 miles
Both tops
No wear on any leather or carpets etc
South Georgia Corvette 402 cid stroker motor
525 rwhp (600 hp at the crank)
Power switch defaults to full power at start up
Previous owner installed brand new trans (blue tag) for sale (previous owner was extremely fastidious and wanted car is absolutely top notch condition for the next owner)
Forced air intake
Big cams (LPE nasty cams - specs available upon request)
Ported and polished intake, injector housings and heads as is expected in a motor of this caliber - Aaron Scott breathed his magic on this motor, and then some
Engine refinished in black crinkle - with red lettering - same as the black widow motors - very striking - see photos
Upgraded Grand Sport calipers and cross drilled rotors
Brand new BFG tires up front, and BFG drag radials in the rear
4:10s in the Dana 44
Hurst short shifter
Stainless Works Headers, with A.I.R. connections
B+B exhaust with OPTIONAL X-pipe installed (car sounds absolutely awesome!!!)
Paint is in perfect condition and freshly waxed and polished.
Windshield is original with only very minimal delamination
Brake ducting to aid cooling of front brakes
Braided stainless brake lines
Raised redline to 7500 rpm
Single Mass flywheel (fidanza) to allow quick spin up of the motor, and she spins up QUICKLY!
Interior - 10/10
Exterior - 10/10
Engine - 10/10
Please post up any questions if you're genuinely interested in buying this beauty. If you're interested in buying a completely pristine STROKER ZR-1, then this is your opportunity. This car not only makes the power you want, and will push your eyeballs into your toes, but it also is showroom stock in appearance and presentation. You would be hard pressed to distinguish this car from a brand new car in 1994. I'll post up photos shortly.
PRICE: $45,000.00
Both tops
Forced air intake
Hurst short shifter
Interior - 10/10
Exterior - 10/10
Engine - 10/10
PRICE: $45,000.00
Very Nice!!!
One other detail: the rims are polished A-molds - stock rims that were polished - so they are light and strong - not aftermarket chrome rims.
I'm going to list this one and the Admiral on C4 for sale section, as well as auto trader and kijiji this week. I'll post the links.
beautiful car. GLWS. you can't go wrong with this one. good stroker ZR-1s don't come up fo sale too often
as Farris B. says "if you have the means, I highly recommend it"
