C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Head light problem
Old 05-13-2013, 03:02 PM
steve carrington
steve carrington's Avatar
Default Head light problem
Hello I'm hoping someone might have a answer for me. My headlights will open up when I turn on the parking lights. They function normal when I turn on the headlights all the way on. Could the problem be the headlight control module? The way it is now I can't run the parking lights with out the headlight buckets up. Thanks for any help.
Old 05-13-2013, 10:03 PM
Hooked on Vettes
Hooked on Vettes's Avatar
Disconnect the five pin plug at the head light control module. (Note the two red wires on that plug are hot all the time).
Use the Black wire on that connector for ground.
Measure the voltage on the Yellow wire with the head light
switch in the Park position. Should read zero volts. If there is 12 volts, the head light switch is bad. If zero volts and the head light motors are opening with the headlight switch in the Park position the control module is bad.
After testing, disconnect the negative battery cable.
Plug the connector back in the control module then reconnect the negative battery cable.
If you don't have a meter or test light an indication that
the problem is the head light switch is if in the Park
position the head lights are on.
Old 05-18-2013, 10:57 PM
1994zr1monster
3rd Gear
1994zr1monster's Avatar
I had the same problem with my headlamp staying up and the shop replaced the module and it was all good after that...
To Head light problem
Quick Reply: Head light problem
