Rebuilt Bilstein's
FX3 Applications 90-91 and 92 and later
Yes I beleive only difference are the top gears which have different stop points. The mounting points and the internal valving are the same however as far as i know. I state this as the 3 selections dont change and are acheived the same way. Only time the valving is changed is when you choose a setting like the moroca valve option.
In regard to applications of FX3 Shocks 90-91 and 92-later (adapting 92' and later FX3s to 90'-91' application).......
I am thinking you can't just change out the gear on a 92 FX3 top as entire rod needs to be changed to adapt to a 90-91 application due to the valving holes. You can use 92 FX3s in 90-91 Application if you upgrade to the newer controller.
Just noticed your post a few minutes ago. I have no complaints. By the time I finished putting her back together around September 1st, I was dealing with a power steering pump issue of my own making. By the time I resolved the power steering issue, it was late November going into December and time to put her up for the winter. I was pretty busy this spring and it just tailed off about a week ago. I just took her for a spin up to my parents house which is about a 2 hour round trip on the turnpike and she drove great. It rained on the way back. She drives a heck of a lot better before the rebuild. Shocks look okay..no signs of leaking oil.
Bad *** on the twisties also. I have GOODYEAR EAGLE F1 GS-D3 on all four corners.
Even my wife noticed last year how much better she drove.
Received 1,864 Likes
Here's another shop that can rebuild Bilsteins that has an excellent reputation for quality work. I talked to one of the owners and was very impressed.
http://texastrackworks.com/
NCM Lifetime # 982
What is the cost & turn around time Clint ?
