C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
ZR-1 Black wheels A-molds OEM
Old 02-03-2013, 10:40 AM
Snuckley
Snuckley's Avatar
Default ZR-1 Black wheels A-molds OEM
I have a set in great condition. 2 Frt 17x9.5in x 56mm offset 2 Rr. 17x 11in. x 50mm offset mounted with Kumho V-Racers DOT 275/45 315/35 with one tract day on them. Located Eastern PA. $1200 local pickup. These wheels also mount on the Blue GS I think ???
Old 02-03-2013, 01:03 PM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
Your 50mm 11" would require a spacer to be run on a ZR-1 for correct appearance. The ZR-1 11" is done in a 36mm offset because of the "body width"!
Old 02-03-2013, 01:24 PM
anniv88
anniv88's Avatar
Yes they do. The black 17x9.5 in. x 50mm is the Grand Sport wheel not the ZR1 wheel.
Old 02-03-2013, 01:51 PM
Snuckley
Snuckley's Avatar
Yep, now it all comes back, these were called the ZR-1 wheel with a GS offset ?? or do I just call them A-molds and folks will know what they are ??? Good news is they are the OEM, Not the aftermarket repos. I used them only for the track on a C5. thanks guys
Old 02-03-2013, 02:03 PM
WVZR-1
WVZR-1's Avatar
The telling tale would be the casting information on the "back-side" that's the "identifier" and nothing else. A buyer will want that information so you might as well tackle it now. They'll also want snapshots I guess but the identifier is the casting information.
To ZR-1 Black wheels A-molds OEM
Quick Reply: ZR-1 Black wheels A-molds OEM
