C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Nice plenums!
Old 12-18-2011, 09:39 AM
erikszr1
erikszr1's Avatar
Default Nice plenums!
hi guys, im curious on what you guys use to make your plunems look soo nice? i look a many of your cars and the engines look outstanding! powder coating? paint N clear? im gonna do injectors soon and i must take this project to the next level for sure. thank you, erik p
Old 12-18-2011, 01:21 PM
rudolph schenker
Support Corvetteforum!
rudolph schenker's Avatar
Paint and or powdercoat!!!
Old 12-18-2011, 03:06 PM
zr-1 guy
zr-1 guy's Avatar
powder and clear or paint and clear. I wish I had digital pics of the 93 ruby car with the ruby powdered jeal motor. you'd need to change your pants
Old 12-18-2011, 03:15 PM
lgaff
lgaff's Avatar
2022 Corvette of the Year Winner -- Modified
2021 C4 of the Year - Modified Winner
Clear coat is tough, tends to yellow.....I would use either a dedicated high temp paint light VHT or check with someone like Eastwood...
Old 12-18-2011, 06:21 PM
Z51JEFF
Z51JEFF's Avatar
Marc Haibeck has a gloss process that looks the best out of all the finishes Ive seen.
Old 12-18-2011, 07:53 PM
ittlfly
ittlfly's Avatar
Here's my Z done by Marc....
Old 12-18-2011, 10:37 PM
-=Jeff=-
-=Jeff=-'s Avatar
Powder coated:
Old 12-19-2011, 01:05 AM
ZR-71
ZR-71's Avatar
St. Jude Donor '15
Originally Posted by -=Jeff=-
Powder coated:
What's that cylindrical thing with the hoses next to the cam cover?
Old 12-19-2011, 03:16 AM
95ZR1
95ZR1's Avatar
Oil Catch Can
Old 12-19-2011, 05:54 AM
Paul Workman
Paul Workman's Avatar
The stainless hex head cap bolts are a nice touch, and very practical too; especially the 4 bolts that hold the coolant pipe to the IHs (injector housings). Those bolts are often exposed to coolant and the stock steel ones often rust around the threads and seize up in the IHs.
Wander over to the ZR-1 Registry for a list of the bolts to buy (from McMaster Carr or whomever) along with the special sealing washers that goes with 'em.
Welcome to the "Brotherhood of the Beast"! It's hard to think of a better pair of stable mates than a C6 Z06 and a ZR-1!
P.
Old 12-19-2011, 08:31 AM
-=Jeff=-
-=Jeff=-'s Avatar
Originally Posted by 95ZR1
Oil Catch Can
Correct, it is an Oil catch can
Old 12-19-2011, 01:17 PM
A26B
A26B's Avatar
P.
You can get bolts you need, original & SS as a full set, individual application sets or even single original bolts.
http://www.jerrysgaskets.com
Old 12-19-2011, 04:06 PM
bb62
bb62's Avatar
P.
I can. How about a ZR-1 with a 67 435HP coupe....
Old 12-19-2011, 04:56 PM
FU
NCM Lifetime # 982
FU's Avatar
Location: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Now THAT is a nice stablemate !!
Old 12-19-2011, 05:50 PM
LT5corsa
1994 Admiral Blue ZZZZZR1
LT5corsa's Avatar
Northeast Events Coordinator
I bought gaskets and SS bolts from Jerry. (also had Marc do the paintwork)
David
Old 12-19-2011, 10:00 PM
rhanselman
rhanselman's Avatar
Here are mine... And I have no idea yet if it's paing or powder...
Old 12-20-2011, 01:00 PM
Paul Workman
Wow! You DO have a point there!!
To Nice plenums!
Old 12-20-2011, 03:34 PM
C4Fanatic
C4Fanatic's Avatar
Powdercoat:
Old 12-20-2011, 04:36 PM
FASTAZU
FASTAZU's Avatar
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Factory
Old 12-20-2011, 05:15 PM
Paul Workman
Originally Posted by C4Fanatic
Powdercoat:
Yeah... I liked that one of yours so much, I hadta take a shot of it too!
One of my favorites..
This is BMW wheel paint from a rattle can. It has a bit of silver metal fleck in it. I couldn't decide if I wanted it silver or some other color, so I figured for under $10 I'd try silver. That was a couple years ago, and that stuff is holding up pretty dang well, surprising enough!
As far as silver goes, Bob G's 427 LT5 is PC'ed and it is the best by far that I've seen - far as silver goes. And, of course there always =Jeff= and that candy-apple red
As for the lettering, I thought it would be a bitch. Well, masking tape IS a bitch to use. But, I ended up tossing the masking tape and simply hand brushing the paint into the letter recesses with a cheap camel hair artist's brush. I was reasonably careful to stay inside the recess boundaries to minimize cleanup, but found it wasn't necessary to be too fussy about getting paint where I didn't want it. (Read on)
Then, I dampened a Q-Tip with fingernail polish remover - just damp (not quite dry) - and wiped the excess paint right off. It was really easy, and the I was able to do it all from start to finish in less than a couple hours, including drying time.
P.
Quick Reply: Nice plenums!
