Stainless steel air box
1994 Admiral Blue ZZZZZR1
This air box is very similar to "the marc Copland air box"
Marc gave permission to redo this box but he asked for it not to be named after him
Price is $500 and includes 2 screws
This will be limited to a maximum of 25 and we can deliver to marc haibecks (april 22)Or Bowling Green (may 16 thru 20)
List thus far:
1 left.
If you need it delivered to BG or Marc's need to RSVP ASAP n (space limited)
Anyone interested payment is going to George Braml and pm me for his info
Regards
David
List thus far:
1 left.
Regards
David
Concur it will not work the AO forced air setup as it relies on a closed lid setup with a tube connector on the bottom feed by an open front license plate diffuser.
However with the front plate diffuser only and this setup it will not hurt to feed air into this open top air system. I think it would only improve as the surface area of the entire filter is not compromised by the limits of the corogated hose and the coffee can size connector to the bottom of the air filter.
More airflow is better for cooling and performance always. An open top element and open license plate diffuser would seem to me to be the best of both worlds. Also this looks great
Assuming the mount screw holes are in the same position, you could probably use the "Forced Air" lid on the Coplon style base. But then you would have a painted black lid instead of the stainless piece.
If you already had the "Forced Air" setup, you could replace the box with the Coplon style unit, and switch lids back and forth at the track to see which one worked best.
My 91', (with stock motor), trapped at 117 mph. with the "Forced Air" installed, so I don't think it was having any trouble breathing.
My car did not have a Coplon box, but I did use a Coplon stainless insert between the "Forced Air" box and the intake horn. This goes inside the stock plastic accordion connector, prevents collapse, and provides a smooth path for airflow.
BTW, that is one gorgeous air box
SS Air Box for LT5 and L98 are Identical
I just went out and checked as both original Air Boxes (91' ZR1 (LT5) and 90' Corvette (L98)) appear to be identical (Metal cover, filter, screws, and Air Box). I just removed accordian air from L98 and fit on my OEM LT5 Air Box and appears to fit perfectly.
George Braml (gbraml@hotmail.com) did a perfect fabrication job on the L98 SS Air Box as he did on the LT5 SS Air Box
The L98 and LT5 SS Air Box and Air Filters are Identical.
I did not Powder Coat or Paint the SS Air Box as it looks very very nice as a SS Machined look and the welding is absolutly perfect......so why cover up with Powder Coating or Paint
Cliff
Received 3,043 Likes
St. Jude Donor '05
Thats SS or alum?
What gauge is that?
Reason Im asking want to make an airbox for a carbed vehicle. not so thick its tough to work with but thick enough it could be welded.
What gauge is that?
Correct Installation of the SS Air Box
If you look closely at the SS Air Box Square Filter Retainer you will see a cut out about 1/4 inch deep and the width of the Square Filter Retainer on the bottom end. The height of the Air Filter cannot be higher than that cut out (The Orange Fram Filter is about 1/4 inch higher than that cut out).
The Key is to get a thinner Air Filter that slides under the front opening in the small cross frame. My FRAM Air Filter installed L98 SS Air Box and FRAM Air Filter is identical to the one you show and also installed wrong on the L98.
I will get the correct K&N 33-2035 Air Filter today identical to the one I have installed in the LT5 and take some close up photos of the issue for you. I will also note exactly the Filter Number so you can also install your SS Air Box correctly. I will also provide a couple close up photos of the Incorrect Installation of the SS Air Box. I have K&N 33-2035 Air Filter on the way and will post to verify that is correct as that appears to be the Air Filter installed on my LT5 that fits perfectly.
The Detailed Technical Discussion is here Stainless Steel Air Box and Air Filter (L98 and LT5)
