C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
4 sale: ZR-1 & C4 Parts and collectibles large list
Old 07-22-2015, 10:41 PM
91vettezr1
91vettezr1's Avatar
Default 4 sale: ZR-1 & C4 Parts and collectibles large list
[[B]B]I have decided to sell a bunch of parts I have accumulated over the past 14 yrs. I have already replaced everything I can on my 91 ZR-1 and since I barely put 1k miles a year on it, I doubt I will need all these extra parts. I have pics available for all listed. See photobucket link. http://s1246.photobucket.com/user/fr...RTS%204%20SALE
I accept paypal, check and money orders. I will accept reasonable offers on all parts. Shipping extra.
TODD CERAMI
21 PARK STREET
BELVIDERE,NJ
07823
908 750 4383
TODDCERAMI@COMCAST.NET (email and paypal address)
COLLECTIBLES:
1. Wall art Thunder at Stillwater Table Centerpiece, # 25 of 25. $550 Very rare.
3)Both variations of the EDS/TOMMY MORRISON posters. Thunder & Lightning (slight wrinkling at bottom right corner $35 & the one with the Helmet & gloves.$45 These are originals not copies.
4) Original GM press photos of the lt5 engine 8.5 " x 11" $25 each. 1st photo pictures lt5 engine in lower caption, lt1 above it. 2nd photo side view 89 zr-1, 3rd photo rear view 89 zr-1. 4th photo 92 zr-1 engine , similiar to Dave Kimble see thru art.
6)1992 GM pro athlete brochure in original mailer .These were mailed to pro athletes back in 1992. $60
7) 1990 ZR-1 owners kit coffee table book, $55 each, 1991 coffee table book $50
8a)1990 Partial ZR-1 Owners kit , Pizza box, 90 driver book,90 coffee table book ,90 video Near Mint . Missing keychain and briefcase. $225
9) 1990 Owners kit video with plastic wallet key $30
10)1994 34" x17" mylar Corvette Admiral Blue dealership poster with chevy frame. $155
12) Tommy Morrison Record breaking Endurance record 8.5” X 11’ card. $25 each
13) ASC original press kit photos of DR-1 (ZR1 convertible) and ASC Spydeer $15 each
14) ASC GENEVE CORVETTE PEWTER AWARD $40
15) Original zr-1 window stickers these came from Old owners kits. 4 different VINS $25 each
16) 1991 NCC POSTER 24" X 36 RARE $70
17) 1990 NCC POSTER 24" X 36 RARE $70
18) 1992 Corvette Delco Bose GM demo CD $35 with mailer
20) 1991 corvette zr-1 prestige brochure $15
21) $20 grand 90 sport zr-1 poster
22) SIGNED CALLAWAY PRINT $45
23) T-SHIRT AND HAT GIVEN TO BOWLING GREEN EMPLOYEES WHEN ZR-1 WAS ROLLED OUT $80 PAIR BOTH NEW/ UNUSED
NOS & USED ZR-1 PARTS, SOME STANDARD C4.
1) NOS LT5 SPARk PLUG WIRES ,MINT IN BOX,sealed."corvette lt5" printed $325.00
2) HP6054 NOS Headlamps , plastic not glass, GE BULB $35 Hard to find.
3)90-95 LT5 Power steering Reservoir NOS 26017982 $100
4)map sensor top aluminum plate, goes on top of map sensor $25
5) NOS 91-95 POWER KEY 12508275 $65
6)92-95 Power Steering pressure hose 77416236 NOS $45
7) Secondary Port Vacuum Reservoir (Part #10067563) holds vacuum $65(1)
8)Hose, Secondary Actuator Vacuum Control Valve #10146221 $115
9) map sensor bracket attaches to rear of plenum #10067781 $50
10)90-95 lt5 valve guide sealed in bag # 10090575 $15 each , I have 25
11) N.O.S GM red replacement wire, no "corvette-lt5 " lettering. Sealed in bags, no box. $60 for the set
12)USED A1097C 90-92 corvette air filter with “AC SPARK” script on side. Correct for 90-92 corvettes. Hard to find and needed for NCRS judging $55
13) A1097C gm air filter in box $30
14) NOS PF970C & these have the correct part # 25014155 black, passed NCRS top flight with this filter. The ones without DURAGUARD are impossible to find. PF970 filter are blue part #25011441. $25 each
15) cam cover bolts #1514330, sealed in bags. Attach cam cover to head. $5 each. I have quite a few of these.
16) cylinder case vent cover gasket sealed in delco bag # 10168682 $15(1)
18 ) Shield, Alternator Blade 1990 - 1995 Model #10153529 $35
21)exhaust manifold round spacers #03983422 $6(4)
22)Hose, Fuel Pressure Regulator 10110987 $25(1)
23)Hose, PCV Valve Connector 1991 - 1995 # 10174350 $60
24)Hose, Cruise Control Servo Vacuum #10110989 $55
25)Grommet, PCV Valve, 90~95 14078872 $25
26)vacuum hose from sec pump to under plenum #10098477 $25
28) original gm wheel weights painted grey different sizes 3 oz, 2oz etc you get 10 weights for $25
29) 1991-1996 Corvette Clutch Hose |braided stainless ,goes from master to slave GM Part # 10150086 $225
30) timing cover gasket 10187758 $25(1)
31) lt5 91-95 Pump, Secondary Port Throttle Vacuum 15198448 nos $165 –
32) Used 90-95 LT5 Radiator part # 3094929 dated 04-90 excellent condition low miles, no leaks $150 –
33) 10193707O / 10282934 rear center hatch trim middle piece came out of 19k zr-1, missing 2 bumpers $60
34) ('91-'96) nos Hydraulic Feed Line GM P/N 12509314 $225
35) Reproduction Cam Cover emblems 1991 or 1990 $35 each
36) 1990 N.O.S. Cam Cover Emblem $55
37) 10110933 top secondary cam timing chain guides nos $40 pair
39) NOS FRONT 13" ROTORS GM (RH)10052204 / (LH)1005220NOS REAR ZR-1 GM ROTORS 10097655,fits either left or right $155 pair
40) used lt5 zr1 LUK FLYWHEEL from 19k zr-1, surface is smooth no issues. 10150026 $350
41) 90-96 corvette upper trim piece driver side, excellent condition no cracks. $65
42) aftermarket complete lt5 hose kit $60
43) 1990-92 LT5 Corvette exhaust manifold shields left complete. right outer shield only $40 all 3
44) used 10156160 antenna , mast doesn't go up $15 removed from 94 zr-1
46) NOS 10225120 Fuel Injector housing gaskets left or right $30 each
47) NOS 1990 Corvette base ,not ZR-1 rear bumper turq. metallic emblem $45 10153697
48) 10153649 Used 91-96 Corvette hood emblem, metal not plastic $20
49) lt5 used connector where both pcv valves connect to pipe $15
50) lt5 nos hose clamps $40 FOR 510153529 lt5 alternator shield nos $40,lt5 10067563 secondary port vacuum reservoir, used but holds air tested $50
51) 90-95 Cam Cover Aneroebic Sealer # 12345980 $20 bottle
52) 92-95 lt5 power steering pressure hose 36-362360 /77416236 $45 nos
54) nos 93-95 egr 12578035 $50 / lt5 rubber piece where pcv connect to.used $20 –
55) 14078872 lt5 pcv elbow $20
57) 1993-95 Corvette LT5 ASR cable used from 55k mile car $75
58) 1990-92 lt5 fr2ls spark plugs $5 each
59) nos Secondary Port Vacuum Actuator (Part #1996743) $135
60) Corvette 84-96 left or right front fender seal 14154943 dated 10/5/94 $30
62) 1993-95 Corvette lt5 platinum spark plugs 5614355 $5 each
63) 1993-95 lt5 nos exhaust manifolds pair $260 25143612 & 25129492 –
64) $45 90's gm cell mint in box
65) nos 96 grand sport Fender stripe 10279781 $50
66) NOS 90-95 LT5 POWER STEERING RESERVOIR 26017982 $95
67) 90-92 LT5 OIL FILLER CAP $50
69) 93-95 ZR-1 LT5 A/C LINES USED. SMALL RUB IN HOSE, DOES NOT LEAK $65 –
70) 10231876 LEFT HAND UPPER FENDER USED $35
71) used left side 14104007 wheel well front $25
Old 07-23-2015, 06:48 AM
DRM500RUBYZR-1
Support Corvetteforum!
DRM500RUBYZR-1's Avatar
Todd,
Sent you a message.
Marty
Old 07-23-2015, 08:51 AM
Goldcylon
Goldcylon's Avatar
Todd can you send a pic of #14 to goldcylon@***.net I might want that?
I will take 2 91 repro cam cover emblems #35 on your list
Old 07-23-2015, 03:19 PM
MickeyD
MickeyD's Avatar
Message sent.
Old 07-23-2015, 03:49 PM
ZR-71
ZR-71's Avatar
St. Jude Donor '15
My goodness, you acquired quite a collection. Thanks for offering
Old 07-26-2015, 11:19 PM
74 LS4-454
74 LS4-454's Avatar
Finalist 2020 C4 of the Year - Unmodified
Todd, just sent an email from FBodies@AOL.com concerning some parts.........Thanks.....Tom
Old 07-27-2015, 07:51 AM
Dynomite
Dynomite's Avatar
How much for Numbers (under ZR-1 Parts Items 1-71) 1, 20, 24, 26, 53, 56 shipped to 93291......Total.
I assume Ash Tray cover is gone??
I assume Secondary Port Throttle Hose Kit is gone??
1) 90-95 zr-1 tire bag torn zipper, bag inside new. $65
20)Original gm Gasket, Set Coolant Outlet Tube 90~95 $12 #10168677
53) nos 90-95 corvette fuel filter gf481 $15
56) 1990-92 Corvette power seat switch bezel $15
Cliff
Old 07-28-2015, 04:23 PM
MickeyD
MickeyD's Avatar
PM sent a few days ago. Did you get? Want NOS passenger side mat. No price on list.
Old 07-28-2015, 04:34 PM
91vettezr1
91vettezr1's Avatar
10153602 gb3 ,should be correct for 89-93? $35
thanks
todd
Old 07-28-2015, 04:40 PM
MickeyD
MickeyD's Avatar
thanks
todd
I'll take it. I'll give you UPS number to ship or mail which ever is easier for you. What's easiest way for you to ship?
Mike
Old 07-28-2015, 04:47 PM
MickeyD
MickeyD's Avatar
Mike
Paypal sent
Old 08-03-2015, 03:07 PM
Goldcylon
Goldcylon's Avatar
Thanks Todd... Items received. GC
Old 08-03-2015, 05:44 PM
Dynomite
Dynomite's Avatar
Give me a total shipped to 93291 for #26) vacuum hose from sec pump to under plenum #10098477 $25
Received the other items in great shape...thanks.
make it $30 total
thanks
can ship tomorrow
PayPaled you for the #26....thanks,
Cliff
Old 08-03-2015, 05:50 PM
91vettezr1
91vettezr1's Avatar
Cliff
make it $30 total
thanks
can ship tomorrow
To 4 sale: ZR-1 & C4 Parts and collectibles large list
Quick Reply: 4 sale: ZR-1 & C4 Parts and collectibles large list
