Valentine Owners
Valentine Owners
So I have had my valentine 1 since like 2000. It's been upgraded once back in maybe 2002. Has anybody done this upgrade and is it worth it?
UPGRADE PROPOSAL FOR YOUR
Serial Number 10159XXXXX
Our upgrade to V1.85 w/ESP, Improved Euro Mode plus Traffic Monitor Filter and Junk-K Fighter will produce the following benefits:
Traffic Monitor Filter, created to eliminate false alarms caused by SpeedInfo, a traffic-flow monitoring system that sends frequent K-band radar bursts into the traffic stream.
Junk-K Fighter blocks false alarms caused by K-band lane-change warning systems in some newer cars.
Improved Euro Mode, now with K-band coverage expanded to include the lower frequency photo radar devices in use in other countries. (V1 is already optimized for North American radar as it comes from the factory; Euro Mode is not for driving here). For specific frequency details, click here. This upgrade will install the Euro Mode but you must activate it. To activate, see http://www.valentine1.com/Lab/techreport3.asp
Crystal-controlled Frequency Tuning to permanently safeguard coverage at radar-band edges.
Extended Serial Protocol (ESP) enables two-way communication with SAVVY and V1connection.
* One-year limited warranty, same as new units, starting at upgrade date.
*--Instant Upgrade to V1.85 w/ESP, Improved Euro Mode, Traffic Monitor Filter activated and Junk-K Fighter activated: As soon as we receive your old unit (in operable condition with no tampering of the serial number) we'll exchange it for a brand-new, current-production V1. This is our way of assuring you'll be without V1 protection for the shortest time.
PRICE: $289 plus shipping
Here's How to Order
Here's How to Order
Pro Mechanic
I got a brand new one in '11 and it is 100% WORTHLESS. All it does is false. Falsey, false, falser. In falses constantly. Even in the middle of F'ing nowhere...route 80, Wyoming. Nebraska. Iowa. There is nothing out there! Farms! And what does it do? It falses, almost constantly. I can put it on Advanced Logic mode and all it does is false.
It is totally worthless b/c anywhere you are, it is going off, so what does that mean? Nothing. I shut it off and throw it back in the center console. Thing is useless. If there is an upgrade that helps, I'm all
I just wonder if its outdated after 15 years
Still seems to work good.
Pro Mechanic
If it works good for you, unless someone comes on here and sings massive praises for a particular upgrade....I'd keep it as-is.
I had an older Valentine (from the '90's) that was stolen a long time ago...but it worked GREAT, back then. So I know they can work well...my newish one doesn't.
Yup me too..... Had mine upgraded and all I get is false warnings especially from the newer cars with blind spot monitoring and backup radar. What a waste.
Pete
Pete
Mine has never been upgraded since I bought it in 2003. It has saved me countless times even though it does give off false messages at times.
It seems to me the airwaves have much more clutter from all manner of sources so the environment has changed in ways that make screening out
false signals harder that it use to be. Keep in mind that situational awareness plays a big part in how you access the threats out there.
Socal is easy... mostly KA band and the CHP drive around with it on all the time. Sometimes they use laser... not often though.
Valentine Owners
I still have my V1 actually I have two (one is very old and was never upgraded). They both work well for me and have saved me some money!
But they do give false alerts, automatic door openers at malls, banks, etc. and now a lot of new luxury vehicles have blind spot avoidance features and radar based cruise control which set off the V1. You have to leave the volume low and try and weed out the false alerts.
A lot of clutter in the air and on the streets.
Im a V1 user and it works great. All radar detectors give false alerts as stated correctly above for the above reasons. The upgrade looks pretty pricey however.
I also use the hidden display and the unit has two volume mode and you can mute out the flase alerts very easily.
However if your getting flase alerts all the time something is wrong with the unit. I drive 70 miles daliy on the freeway and in around the down town area all the time. It only false alarms in one area. every day same area. I just ignore it.
Im a V1 user and it works great. All radar detectors give false alerts as stated correctly above for the above reason. The upgrade looks pretty pricey however.
I also use the hidden display and the unit has two vaulme mode and you can mute out the flase alerts very easily.
However if your getting flase alerts all the time something is wrong with the unit. I drive 70 miles daliy on the freeway and in the down town area all the time. It one false alarms in one area. every day same area. I just ignore it.
