C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Another new ZR1 owner
Old 07-22-2011, 10:01 PM
Y-ME
Y-ME's Avatar
Default Another new ZR1 owner
Just picked up my first ZR1 and like 10th Vette off of the forum. It's a 90 with 77k and she needs glitch type stuff that I could use some advise from those familiar with the LT5 as I have pretty much all the LT1 and L98 experience. She throws an Ecm code 33 for low map sensor pressure, where is the Map on this thing? Second the secondary air pump under the pass headlight growls when I turn the key, and then on occasion with the key car off on this coupled with fact that sometimes it takes forever for her to idle down from 1500 rpm tells me there is a vacuum leak somewhere, where does the vacuum line that comes from the pump go? it disapears under the Plenum. I don't hear any hissing so any ideas where I should look or look for? It just got a new starter so the plenum was just off.
2nd when you let off the clutch to take off at low throttle it is unsmooth, Pressure plate? not alot of clutch work in my past.
A/C no workie compressor does not cycle on I'm not that great with a/c but it looks to have a newer compressor on it as it has crimps attaching the wires to the connector It has the conversion fittings, when I attached a can of freon the guage was way in the red I let some pressure out but still no cycling on by the compressor.
P.S. not that I need to but how in the world would you get the rear torx screw out of the pass side cam cover?
Thanks for the help guys.
Old 07-22-2011, 10:07 PM
lgaff
lgaff's Avatar
2022 Corvette of the Year Winner -- Modified
2021 C4 of the Year - Modified Winner
Join the ZR-1 registry, forum is free... ZR1.net
There is a map sensor behind the plenum under an aluminum plate
There is a 2nd under the ECM
The rough ride might be the map
the air pump creates vacuum and it will cycle when it first turns on....and when pressure drops every 30 seconds or so is probably acceptable......every 90 sec or more is more normal...possible vac leak under the plenum
trace the line to the rubber grommet that leads to a hard line that runs under the plenum, attach a vac hand pump and see if it holds
Most importantly join the Wazoo group in your area,....
Old 07-22-2011, 10:53 PM
Y-ME
Y-ME's Avatar
The idle is not rough just high for awhile. The roughness is definetly in the drivetrain (not motor). That pump growls like every 5 seconds.
What the heck is a Wazoo?
Old 07-22-2011, 11:02 PM
lgaff
lgaff's Avatar
group of guys that get together, and help fix each others Zs.....in your area I believe...they use a lift
seriously join the registry
If pump is going off every 5 seconds you have a vac leak
Old 07-22-2011, 11:04 PM
lgaff
lgaff's Avatar
http://www.zr1.net/forum/showthread.php?t=14133
Old 07-22-2011, 11:33 PM
zr-1 guy
zr-1 guy's Avatar
high or hanging idle is probably the chip and yes you need to get on the registry site
Old 07-22-2011, 11:45 PM
Y-ME
Y-ME's Avatar
So is the chip bad or is it normal operation?
Old 07-22-2011, 11:46 PM
rickyrj1
rickyrj1's Avatar
WAZOO crew would have you fixed up in no time. You pay for the parts the labor is free but you might have to buy the beer
Old 07-23-2011, 12:07 AM
Y-ME
Y-ME's Avatar
Except that "registry" wants 45 bucks to join, no thank you.
Old 07-23-2011, 12:09 AM
lgaff
lgaff's Avatar
The forum sign up is free....
Old 07-23-2011, 12:50 AM
zr-1 guy
zr-1 guy's Avatar
except that the registry forum is as free as this one....you're welcome
and yes the chip is working "normally" it's not "bad" just needs some updating. give mark haibeck an email at www.zr1specialist.com and get a new one made
Old 07-23-2011, 07:01 AM
bldavis11
bldavis11's Avatar
Whoa... before dropping $100 on a new chip, get your MAP code fixed first. Mine had the exact same problem which completely resolved after I traced down and corrected the vacuum leaks.
Don't bounce the registry just yet either. Take a look around at the forums and make up your mind. They don't have ads plaster all over the place and do have to pay for the site. You get all kinds of ZR-1 gear and it's a family... way better than the usual CF crowd.
Old 07-23-2011, 12:06 PM
FU
NCM Lifetime # 982
Support Corvetteforum!
FU's Avatar
Location: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
45 bucks ? Wow that's a lot of money. I could get a half tank of gas with that.
Old 07-23-2011, 01:58 PM
phrogs
phrogs's Avatar
$45 bucks a bunch of knowlage and a T-shirt!
If you go to places like Carlisle you get free beer from the ZR-1 registry but only if your a mamber.
Old 07-23-2011, 02:00 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Just join the forum there its free youll find more answers on your Z there before here.. Just tryin to help.
-Former Z owner
Old 07-23-2011, 02:01 PM
WydGlydJim
WydGlydJim's Avatar
The car could have an issue with the idle and a vacuum leak, but the idle return on the '90 in particular was a point of contention for owners. Return to normal idle could take as long as 30 seconds, and is completely normal, although it seems like forever after you have come to a complete stop. When you are still rolling a little bit, the idle will stay up some, as it does between shifts.
Old 07-23-2011, 03:50 PM
jrd1990zr1
jrd1990zr1's Avatar
As Ricky said. Good group of guys, burgers at Carlisle, tee shirt and lots of advice for ZR1 owners.
Well worth the $45.00
To Another new ZR1 owner
Old 07-23-2011, 04:26 PM
rickyrj1
rickyrj1's Avatar
Best $45.00 you'll ever spend. Several of the members busted their *** all day helping out a fellow members grandson put in a clutch on a non ZR-1 Corvette. Sorry your not able to see the value.
Old 07-23-2011, 06:22 PM
mike100
mike100's Avatar
You can make a couple of tweaks in the chip to coax the target idle lower, which seems to reduce the 'idle hang' a little also. From what I understand, the early 91's and 90's had this condition especially bad...so that's normal, although it could be worse with a vacuum leak.
If you are idling at 1200, that's a leak, but if it runs at 800 or so in the morning after the initial speed settles, you're probably ok with all the hose connections. The throttle body can have a bit too much bypass air- mine did.
Old 07-23-2011, 07:00 PM
secondchance
secondchance's Avatar
We, WAZOO, have the best and the latest tranny jack - his name is Darrin!
Quick Reply: Another new ZR1 owner
